Could it be TB reset?
Old Nov 21, 2006 | 06:12 AM
Theatrix's Avatar
Theatrix
Professional
Default Could it be TB reset?
Replaced plugs and removed and replaced upper and lower plenum. Throttle Body gasket was not sealing correctly so had a vacuum leak when starting. Replaced gasket and now it runs sluggish at idle or when a accelerating.
Could the Throttle body have to be reset?
Old Nov 21, 2006 | 07:26 AM
DayBlueZ's Avatar
DayBlueZ
Won't hurt to do it. Did you get a SES light?
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
aarrgghh
May 1, 2022 11:04 AM
bneumann
Oct 7, 2015 12:16 PM
rizzla
Sep 29, 2015 03:58 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
