Dealer gave me 10w-30 instead. Should I worry?
Old Nov 28, 2006 | 11:17 PM
rockinbboy's Avatar
rockinbboy
Default Dealer gave me 10w-30 instead. Should I worry?
I've had Pennzoil 5w-30 since I got the car and followed maintence by the book. I just got my oil change last week at a new dealership and they used Shell 10w-30. I didn't notice this till I got home and read the paperwork. I feel like going back and asking them to change it to 5w-30. Not sure how I feel about Shell oil. I never used it. I've used Penzoil in my camry and its been fine so far.
Old Nov 29, 2006 | 08:08 AM
VO...'s Avatar
VO...
Administrator
nothing to really worry about. I noticed you live in MD. Thinner viscosity/weight is generally used in colder climates, but there isn't a drastic difference between 5w-30 and 10w-30. The lighter oil is used because it circulates faster when it's cold. This is better for the engine. Most engine wear & tear occurs during startup. Another factor for using thicker oil is when your engine gets older. Thicker oil will last longer in the engine, because it's thicker and won't find it's way into worn out gaskets/rings, thus getting burnt off. You don't have anything to worry about. How many miles on your car anyway?
Old Dec 1, 2006 | 09:35 AM
kaybee650's Avatar
kaybee650
nothing should be wrong , it might take a lil longer to start up the car. because it has to do with the thicker oil a 5 weight vs a 10 weight on start up, but it should be fine, im doing 10-30 also.
Old Dec 1, 2006 | 11:08 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
10W-30 is listed in your owner's manual as recommended oil weight. Worry about what?
Old Dec 1, 2006 | 12:18 PM
rockinbboy's Avatar
rockinbboy
Hmm...mine says 5w-30 as the recommended. I guess I won't worry too much then, just being extra paranoid.
Old Dec 1, 2006 | 02:42 PM
shinkuu's Avatar
shinkuu
you're fine with 5w30 10w30 or 10w40
It says 5w30 in the manual to cover the cold regions.
Old Dec 1, 2006 | 03:07 PM
Mike Wazowski's Avatar
Mike Wazowski
dude, you better drain that stuff out right away to avoid catastrophic engine failure.
Old Dec 1, 2006 | 04:09 PM
kaybee650's Avatar
kaybee650
wow such sarcasm
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
10W-30??!?!? you are going to DIE!!!
Old Dec 2, 2006 | 12:18 PM
Netko350Z's Avatar
Netko350Z
Oh Noes!!1!!!!!!111!1!one!1!!
Old Dec 2, 2006 | 06:57 PM
JonsilvZ's Avatar
JonsilvZ
I use Mobil 1 10-30w because its synthetic.
Old Dec 2, 2006 | 07:19 PM
tyler_seiner's Avatar
tyler_seiner
1) why aren't you using fully synthetic oil and
2)PENNZOIL is the WORST OIL EVER!!!!!
Old Dec 3, 2006 | 11:12 AM
ZPatrick's Avatar
ZPatrick
[QUOTE=tyler_seiner]1) why aren't you using fully synthetic oil and
2)PENNZOIL is the WORST OIL EVER!!!!![/QU
+1
Pleask
Dec 21, 2021 03:17 PM
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
Ronso
Oct 30, 2015 12:39 PM
samansharif
Sep 25, 2015 12:31 PM
