arg, anyone have a strategy to remove the hood without opening it
Old Dec 11, 2006 | 12:08 PM
ares's Avatar
ares
Veteran
Default arg, anyone have a strategy to remove the hood without opening it
gave this lady a bit of a tap the other day.
my car appeared fine at the time.
now Ive found out that the hood apparently did get pushed, the gaps arent even anymore and the hood seems to be hanging on something on the back passenger side hinge area; prohibiting me from opening it.
anyway; I assume the hinge is bent or something, should be easy to replace or just bend back. but I have to get to it... catch 22.
so how do I remove the hood without opening it? can I remove the quarter panels and get to it from there?
Old Dec 11, 2006 | 03:13 PM
UnderPressure's Avatar
UnderPressure
Nope, sorry your screwed.
Going to have to force the hood open. No other way.
Old Dec 11, 2006 | 03:17 PM
disturbed2483's Avatar
disturbed2483
to remove the fenders you have to remove the hood, so like said above you have to force it open.
Old Dec 11, 2006 | 04:45 PM
THE TECH's Avatar
THE TECH
So you're trying to steal a Z eh??
j/k
Old Dec 11, 2006 | 04:48 PM
Mike Wazowski's Avatar
Mike Wazowski
plasma cutter?
Old Dec 11, 2006 | 04:58 PM
plumpzz's Avatar
plumpzz
Originally Posted by USN HM 350Z
plasma cutter?
Reverse flux capicitor powered photon ray splitter... gun.
Old Dec 11, 2006 | 07:44 PM
ares's Avatar
ares
Veteran
so I have to destroy my hood(which is otherwise fine) if I ever want to change my oil...
damn, I better not leave my lights on.
Old Dec 11, 2006 | 07:49 PM
MR_X's Avatar
MR_X
Try to remove the bottom splash shield then get something under there to push/force the hood open.
Old Dec 11, 2006 | 08:34 PM
Scarab440's Avatar
Scarab440
I know you've probably tried this... but have you tried having someone put the release while you pull up on the hood with your fingers?
Old Dec 11, 2006 | 08:54 PM
UnderPressure
Post up a pic of the damage.
Old Dec 12, 2006 | 06:11 AM
Eazzy's Avatar
Eazzy
If u were nearby , I could get it open, Where there is a will there is a way ---Through the yrs Iv done a bunch ---68-82 Vetes were a major pain, but there was a failsafe,Ur lucky,Its usually cuz someone broke the cable. U just have to be inovative
Old Dec 12, 2006 | 05:45 PM
ares's Avatar
ares
Veteran
it pops open fine, itll even lift about 3 or 4".
then it feels like theres something binding or catching; you can feel its the passenger side too.
Old Dec 12, 2006 | 05:56 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Hmm? When you lift it, do you see the hood rubbing the fender towards the top corner? Sometimes when the hood is knocked out of alignment, those two pieces will hit.
Old Dec 12, 2006 | 07:05 PM
Eazzy's Avatar
Eazzy
All u can do if it is unlatched is determain where its hanging up, if its at the rear and u can see where, then grasp the hood on both sides and give it a solid very firm pull in the appropiate direction, U have to put a little *** behind it. If u do it right and arent afraid of putting some pressure on it, it will come. After it does,buy 2 hinges.
A lot of align probs ( doors,hoods,hatches etc ) are remedied on the later cars just that way.
Same as reassembly,if there is no damage and u have adjusted ur hinges the best u can ---Give it a tug.
BTW---Seems to me the hinge bolts are under the fender so u may have a little work to do
Old Dec 12, 2006 | 07:07 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Hit it with a big hammer. like the saying goes:beat it to fit, paint it to match. hahaha
good luck
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
