Hit debris now droning sound
Old Dec 20, 2006 | 01:45 PM
berralman's Avatar
berralman
Default Hit debris now droning sound
I was on my way to my buddy's house when I hit some debris on my front left tire. When I pulled over to see if there was damage I saw a bubble on the sidewall of my tire. Later when I drove back there was a droning sound coming from the left fender well with the bad tire. It was very continuous so I suspected something came loose or my tire was out of balance or bent. After getting the tire replaced today I still get the droning sound. I asked the mechanic before I left and he said it wasn't bent. I also checked the fender well and under the hood but could not see anything loose or stuck. Could it be that my car is out of alignment or maybe the rim is bent?
Old Dec 20, 2006 | 10:56 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Maybe something bounced under the car and has loosend something. Might pay to get it properly checked, unless you have access to a hoist. Good luck.
ps. Stuffed rims can make a noise, does it feel different to drive or noticeable so on the wheel that was hit. Takes only a small dent in rim to be noticeable.
Old Dec 20, 2006 | 11:00 PM
Sean's Avatar
Sean
droning sound may be tire scraping plastic tire well cover when wind pushes it closer to the tire
Old Dec 21, 2006 | 03:56 AM
berralman's Avatar
berralman
The driving feels the same its mainly the droning noise. I dont remember seeing any plastic out of shape but it was dark and i couldnt get really under it. Hopefully its not a bent rim, but I guess I can test that theory out by putting on the spare tire.
Old Dec 21, 2006 | 06:37 AM
Sean's Avatar
Sean
make sure plastic parts haven't pulled free of some fasteners, you wouldn't see anything....check by hand
Old Dec 21, 2006 | 08:06 PM
berralman's Avatar
berralman
A friend and I pulled off the tire and did not see any loose parts. The rim looked fine as well. I'm pretty much stumped. The last thing my buddy said was that it could be a ball bearing in my hub. You cant really hear the droning sound till about 30+ mph. Any other suggestions?
Old Dec 21, 2006 | 08:16 PM
Sean's Avatar
Sean
bearing will turn into a high pitch squeal if it's going bad
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
