engine removal advice needed
Old Dec 23, 2006 | 08:25 PM
danstam's Avatar
danstam
Default engine removal advice needed
I need to replace my engine. The factory manual recommend to drop the engine and transmission together. Anyone know if there is room for the engine to come out from top? Also factory recommended to remove the A/C? Can you do it without removing the A/C? I don't want to recharge the system if I don't have to. Anyone with experience please jump in. Thanks.
Old Dec 23, 2006 | 09:09 PM
DaveZ06's Avatar
DaveZ06
try "tech area" under "Engine, drivetrain, forced induction" you can get a lot of help there
Old Dec 23, 2006 | 09:23 PM
icepig's Avatar
icepig
Is that part of the 24-month service?
Old Dec 24, 2006 | 05:00 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You can unbolt the AC from the block and leave everything connected just move it to the side. The easiest way to pull the motor is taking off the front and pulling the motor and tranny out through the front. Look in the FI area @ some of the projects that people have done. There's some pics.
Old Dec 24, 2006 | 07:04 AM
gringott's Avatar
gringott
Shoot, I missed that. No wonder mine runs a little rough. Have I voided my warranty by not replacing engines every 24 months?
Old Dec 24, 2006 | 04:18 PM
icepig's Avatar
icepig
I'm afraid so. I checked the service manual and we should also rotate the doors and hood/trunk every six months. Service on this thing is a biatch. However, the tires should be fine for at least 100,000 miles.
Old Dec 24, 2006 | 04:26 PM
gringott's Avatar
gringott
I caught the door, hood/trunk thing, but for some reason I missed the engine thing. Thanks for the heads up.
350z_z33.
Jul 3, 2017 04:01 AM
codek
Sep 27, 2015 03:21 PM
_koubie_
Sep 20, 2015 06:34 PM
