Took my 2003Z to the dealer
Old Jan 8, 2007 | 08:14 PM
350xfire's Avatar
350xfire
Default Took my 2003Z to the dealer
Things to do:
1. Fuel filler recall- everything went well
2. Crackling noise on rear end- dealer says they removed the drive axle and packed with grease. Also replaced axle bolts. Supposedly a TSB out there for that.
3. Knocking noise on front passenger suspension when turning- supposedly loose bolts on front sway bar and/or A-arm. I find hard to believe on a 9l mile car, but....
4. Very small grease leak on front U-joint- dealer to replace drive shaft under warranty.
I would like to know if anyone else has experienced these issues?
Old Jan 9, 2007 | 03:40 AM
insomniaxvi's Avatar
insomniaxvi
Axle clicking is a common issue with the '03s from what I understand; in fact, mine just started making a knocking noise the other day... guess I should take her in.
Other than that, not completely sure...
Old Jan 9, 2007 | 03:50 AM
_Donovan_'s Avatar
_Donovan_
Originally Posted by 350xfire
Things to do:
Yeah, mine does that crackling when turning from the front also. Let us know what they say about that.
Old Jan 9, 2007 | 04:29 AM
Mike Wazowski's Avatar
Mike Wazowski
Things to do:
There are TSBs/recalls on all those things, so it is quite common.
http://www.nissanhelp.com/Models/200...escription.htm
Old Jan 9, 2007 | 04:44 AM
Z_rican's Avatar
Z_rican
How long does it take do get the fuel hose recall done?
Old Jan 9, 2007 | 05:02 AM
350xfire's Avatar
350xfire
Should not take more than about 4 hours
Old Jan 9, 2007 | 05:04 AM
350xfire's Avatar
350xfire
Crackling is in the back. Knocking is in the front.
They had to remove the rear axles and lube and change ot retorque the bolts.
Front, it was some bolts that had come loose.
Z_rican's Avatar
Z_rican
4 hours is not bad. I am moving to FL soon and I want to get this recall done ASAP.
Old Jan 9, 2007 | 04:18 PM
whoopazz1's Avatar
whoopazz1
You know what I have my front knockin as well... and was wondering if I should take it in. But since my Z is parcked for the winter... I guess I'll have to have a look underneath in the spring.
Old Jan 9, 2007 | 06:07 PM
350xfire's Avatar
350xfire
Oh, btw, the driveshaft is being replaced due to a small grease leak on the front u-joint.
Pleask
Dec 21, 2021 03:17 PM
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
Ronso
Oct 30, 2015 12:39 PM
