Anyone NOT have the rear axle clicking TSB performed yet?
Old Jan 8, 2007 | 09:20 PM
mavtais's Avatar
mavtais
Default Anyone NOT have the rear axle clicking TSB performed yet?
I still haven't done it on mine, but I'm pretty sure I have it. When I take off from a stop (just like the TSB says: http://www.nissanhelp.com/Ownership/.../NTB04-065.htm ) I can hear tiny wrenches knocking on a metal pipe. I read that is what the rear axle clicking is supposed to sound like. I've had it since 6000-ish miles. I'm now over 27000, still clicking. Anyone not do it even though they have that symptom? What will happen if I don't do it?
Old Jan 9, 2007 | 01:23 PM
mavtais's Avatar
mavtais
Anyone? I'm going in to the dealer tomorrow morning. My ABS is kicking on, and I'm wondering: if you don't do the rear axle clicking TSB, would it have anything to do with the ABS magnetic sensors coming apart and not being able to sense speed? Could the overtorqued center lock nut (which causes the rear axle clicking) eventually pull the rear axles away from the magnetic ring that reads their speed which in turn gives us our speed, which also is the point where the ABS senses wheel lock?
See instruction 4b on the TSB. It specifcally states:
"If the center lock nut is over tightened, the incident may re-occur."
Old Jan 9, 2007 | 02:12 PM
The rear axle clicking sounds like coins dropping on the pavement. If the axle is not clicking, Nissan will not fix it: there is nothing to fix.
Old Jan 10, 2007 | 07:31 AM
mavtais's Avatar
mavtais
OK. This further confirms that I have the axle-clicking symptom. But is it a problem if someone drove with the symptom "unfixed" for more than 7000 miles?
Old Jan 10, 2007 | 07:37 AM
AroundMyHorn's Avatar
AroundMyHorn
i get that sound in first gear but i thought it was clutch related
Old Jan 10, 2007 | 09:22 AM
THE TECH's Avatar
THE TECH
I still haven't fixed mine. It's just not on my priority list yet. When I do it though, I'll just end up doing it myself. I don't trust any dealer with my car.
Old Jan 10, 2007 | 09:35 AM
dkmesa350z's Avatar
dkmesa350z
Mines done it since I bought it at 24K and after 10 thousand miles I haven't fixed it yet
Old Jan 10, 2007 | 09:55 AM
highside107's Avatar
highside107
Yeah, I heard it's no biggie if it doesn't get fixed. But my question is: why NOT get it fixed? It's free and literally took my dealership an hour to fix while I waited.
Old Jan 10, 2007 | 09:57 AM
mavtais's Avatar
mavtais
Any mods to your drivetrain, like an aftermarket diff?
No ABS issues?
Old Jan 10, 2007 | 10:48 AM
Eazzy's Avatar
Eazzy
52,000 on my 03 and havent had the symptoms as of yet---When and if I do , I will just fix it myself and add some unrelated susp. mods
Old Jan 10, 2007 | 11:24 AM
HARRYPOTTER's Avatar
HARRYPOTTER
did n't do mine...but i'll do it myself
Old Jan 11, 2007 | 09:29 AM
mavtais's Avatar
mavtais
Got my car back from the dealer last night. 7000 miles of clikety-clack-pop from the Nismo LSD was enough to loosen the ABS mounting bolt. The bolt was re-tightened, the LSD was adjusted to the lowest setting (took them like 2 hours on the phone with NISMO), and I was told that the TSB was already performed.
So I can conclude that if you don't do the TSB, it's no big deal at all.
Thanks.
Old Jan 24, 2007 | 11:41 AM
DouBLeJ16's Avatar
DouBLeJ16
I just took mine in today for the axle clicking problem.. It's an '04 with 21,000 miles. Only happens in first gear on acceleration.
They said this was a very common problem and it should be fixed. I'll let you know if they come through.
Old Jan 24, 2007 | 12:53 PM
VO...'s Avatar
VO...
Administrator
Some of us have highly modded cars that we wouldn't want a dealership to mess around with and damage something.
Old Jan 24, 2007 | 12:54 PM
VO...'s Avatar
VO...
Administrator
I'm around 28,000 ish and haven't taken it in yet. Been clicking for a long time now. If it breaks, I'll end up doing the repair myself.
Old Jan 28, 2007 | 06:40 PM
DouBLeJ16's Avatar
DouBLeJ16
They fixed mine by removing and lubricating the axle. Doesn't click at all anymore.
Old Jan 28, 2007 | 06:51 PM
y_b_lamron's Avatar
y_b_lamron
I have 99k miles on mine. brought it in at around 35k for the clicking but it came back shortly after. I never brought it back in.
Old Jan 28, 2007 | 09:52 PM
Yes. Those who do not have a clicking problem.
Old Jan 30, 2007 | 05:53 AM
Jcolman's Avatar
Jcolman
werd. I've got 36k miles on my 03 and I've never had a clicking problem.
Old Mar 21, 2007 | 03:06 PM
gto88's Avatar
gto88
Default rear axle clicking
I am having problem to have the Nissan at stevens creek to fix mine.
I have to show their senior technician how the clicking happen, and after 2 whole days of tests ( I had to leave my
car there twice for two days), and they came back as:
"it is normal, and they have 2 other cars having clocking sounds".
What??
I told them, this is my 5th cars I have bought new, and none of the other 4 did this.
The just don't want to try the TSB, is it so hard?
Can anyone tell me where I can get this fix in bay area.
thanks,
