Electrical issues (Man down, Man down)
Old Jan 15, 2007 | 04:22 AM
HackneyG's Avatar
HackneyG
Default Electrical issues (Man down, Man down)
Recently I installed a headunit in my 2003 enthusiast. After the install, my turn signal indicators in the car stopped working, my computer no longer retains information (i.e. trip distance, tire pressure, rpm...) and my odometer resets everytime I turn off the car. Oh yeah, and my mirror will no longer open my garage. The light on my mirror just stays green the entire time, even if I press it, it will still stay green. I checked all of the fuses inside of the car, and all of them seem to be fine. Can anyone help me out?
Old Jan 15, 2007 | 06:35 AM
THE TECH's Avatar
THE TECH
You must have shorted a wire. Double check your stereo connections to make sure there isn't a bare wire touching metal anywhere. Are you sure you checked ALL the fuses?? You actually pulled them out and inspected them?
Old Jan 15, 2007 | 07:19 AM
HackneyG's Avatar
HackneyG
How could I possibly short a wire when all that I disconnected was harnesses? I'll double check again, but I am pretty sure that none of the fuses are blown. This sucks, I don't want to take it to the stealership.
Old Jan 15, 2007 | 07:24 AM
THE TECH's Avatar
THE TECH
Well the last place I would take it to was the dealership. If the only thing that changed was that you did a stereo install, then most likely it was something that you did while doing the install. I'd double check all connections.
Old Jan 15, 2007 | 07:52 AM
srobert910's Avatar
srobert910
There is a secondary fuse panel located close to the firewall behind the battery. You'll have to take the plastic panels that cover the battery area off. It has a black cover over the fuse panel. Quite a few of the constant power circuits run through that panel, radio constant, parking lights etc... That's where I would check first. Also if you pulled the center console for any reason, you might have unplugged the hazard switch.
Old Jan 15, 2007 | 08:19 AM
HackneyG's Avatar
HackneyG
Thanks, I'll check the fuses behind the battery, I forgot about those.
The hazards still work. The indicators in the gauge cluster don't work. You know, the ones that tell you that the hazards lights are on.
Old Aug 24, 2009 | 11:22 PM
GixxerSteve's Avatar
GixxerSteve
I know this is bumping an old thread, but I had the same exact problem. I was messing around with the aftermarket Clarion HU in my 2003 Performance. After I put it all back together, the turn signal indicator lights on the dash werent working or clicking, the trip odometer was resetting to zero every time I turned the car off, and the TPMS light was on. Since I know that all of my wiring connections were solid, I checked the fuses on the driver's side kick panel. Found the 10 amp fuse for "electronics" blown. Replaced it and everything works fine again.
The only thing I can figure is that I did turn on the ignition while I had all of the center console harnesses disconnected (the white box, the hazard switch, the upper gauges). Perhaps that creates a fault or short and blows the fuse?
Old Sep 10, 2009 | 09:57 PM
Chuck1000rr's Avatar
Chuck1000rr
Talking
Gixxer man, you are a life saver I had the same problem you guys described I cheked the fuses none blown but took them all out and put them back like the panel said and "BAM" it works. now just need it to get into promaming mode for the fob, thought this would solve that issue. mabe i need to drive it foe a while and try it againg. thanks for bumping this old tread.
sherm
Apr 11, 2020 05:21 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
