350z engine sound - another one to listen to
Old Jan 27, 2007 | 07:06 PM
pedroosan's Avatar
pedroosan
Default 350z engine sound - another one to listen to
Pls listen to this at higher volume to hear the knock:
Click here to listen to 350z-engine
Can anyone tell me if the knocking sound is normal?
It is audible from inside the passenger cabin, but best close to the engine where the intake pipe is.
I am not sure if it is related to the fuel damper TSB, the fuel damper vibrates, but not that much.
When stepping on the gas the knock gets faster.
Thanks!
Old Feb 2, 2007 | 12:26 PM
pedroosan's Avatar
pedroosan
No one?
Old Feb 2, 2007 | 09:00 PM
ZPatrick's Avatar
ZPatrick
I also heard that sound from my engine too
Old Feb 2, 2007 | 09:02 PM
ZPatrick's Avatar
ZPatrick
Thanks![/quote]
+1
Old Feb 2, 2007 | 09:11 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
maybe a sound when u are reving might be helpful
Old Feb 3, 2007 | 10:54 AM
pedroosan's Avatar
pedroosan
When revving it is much harder to hear because other noises are louder.
Only at warmed up idle is it clearly audible.
Old Feb 8, 2007 | 02:18 PM
Old_Man_Z's Avatar
Old_Man_Z
I have a 05 6spd and it does that a little too. Any one know if this a problem?
Old Feb 9, 2007 | 07:28 AM
imjdoggie's Avatar
imjdoggie
Definitely does not sound normal man I would have it checked by the local stealership.
Old Feb 14, 2007 | 09:27 PM
Cheezwiz's Avatar
Cheezwiz
Sounds like a valvetrain noise for sure.
Old Feb 21, 2007 | 07:46 PM
dave3529's Avatar
dave3529
my car just 2 days ago started doing that and i just came across this to night, the valve train noise is normal in that clip but did anyone notice the very very slight knocking noise in that? mine only does it at warmed up idle also, and i ruled out detination with my scanner, so what else could it be? is it normal on highmileage z's?
Old Mar 8, 2007 | 08:57 PM
dave3529's Avatar
dave3529
i jacked my car up and i can clearly hear that same knocking coming from the lower part of the block. only at idle but warm or cold. does that sound like a spun rod bearing?
Old Mar 8, 2007 | 09:29 PM
johnoppa's Avatar
johnoppa
sounds like my car. I got higher mileage though.. @67k
My friend's z has 30ishK and it's absolutely quiet with minimal valvetrain chatter
Old Mar 8, 2007 | 10:55 PM
pedroosan's Avatar
pedroosan
did anyone try the fuel damper TSB? Not sure if this sound is related to that TSB...
Old Mar 8, 2007 | 11:06 PM
dave3529's Avatar
dave3529
no, but the fuel damper is a ticking noise from the top of the engine. this noise is a deeper knocking noise from the bottom end of the engine. i couldn't tell where it was coming from at first, it is very very very faint from the interior, and even from outside the car, so then i took a listen under neath and now its clear. its very noticeable under the car. which doesn't bother me as much just worrys me because 2k miles ago it didn't do this. unless i just couldn't hear it before because it got worse or something.
Old Mar 9, 2007 | 09:56 PM
dave3529's Avatar
dave3529
does a spun bearing get louder and louder as the rpm increases or quiet down or just get drowned out?
Old Mar 9, 2007 | 11:02 PM
pedroosan's Avatar
pedroosan
I don't know the answer, maybe someone else can help...
Only thing I can say for my knock, frequency increases with RPM.
And probably loudness does not change, only gets drowned out with other noises, or by AC or transmission noise.
It only is clearly audible when everything else is quiet (idle, no street noise, possibly clutch depressed and in gear, AC off, door open or near engine)
Also with higher RPM as the frequency goes up, you don't hear a clear knock-knock-pause-knock-knock anymore, but it becomes a knknknknknkn
if you know what I am trying to say (more of a constant noise).
So chances are you didn't notice it before.
Mattg350z
Oct 2, 2015 06:51 AM
_koubie_
Sep 20, 2015 06:34 PM
