Driver door rattle
Old Feb 1, 2007 | 05:49 PM
LSRoadster's Avatar
LSRoadster
Default Driver door rattle
This is my second Z so I know it must be a common, first car was a coupe and now a ZR. somewhere inside the drivers side door there is something loose, as soon as there is any bass coming through the speakers I get a very annoying rattle, anyone know what it is and know how to fix it?
Old Feb 1, 2007 | 05:51 PM
crowe's Avatar
crowe
I have the same problem with the passenger side door, I thought it was my speakers at first, but I think it's the arm pad piece that's attached to the panel with the switches, I'd like to know if anyone has fixed this as well.
Old Feb 1, 2007 | 06:02 PM
LSRoadster's Avatar
LSRoadster
I know it is not the speakers, but something loose in the door panel, if I press on the door the rattle stops.
Old Feb 2, 2007 | 08:52 AM
cubu's Avatar
cubu
i have that in my passenger door, when i roll the window down more than an inch or so it stops, stops when i push the door in near the tweeter too
Old Feb 6, 2007 | 07:03 AM
LSRoadster's Avatar
LSRoadster
Mine dosent care where the window is, but when I push on the door is does stop.
Old Feb 6, 2007 | 10:45 AM
y0shi's Avatar
y0shi
mine passenger side door rattles too... anyone know what the exact problem is? and is there a fix for it?
Old Feb 6, 2007 | 11:22 AM
LSRoadster's Avatar
LSRoadster
A lot of people seem to have this problem, yet when I call Nissan and ask them about it, they say that they have never heard of this.
Old Feb 17, 2007 | 02:39 PM
dgz32's Avatar
dgz32
Had the same problem. Pulled the door skin off and tightened all screws as some were loose. I then placed pieces of foam material (had an adhesive strip and came in a roll - bought it from Home Depot) at several points where the clearance between the back of the skin and the door were close. Also doubled-up in the areas where there was factory foam pieces. Solved my problem, 3+ years and counting.
|dg
Old Feb 17, 2007 | 04:20 PM
2004LeMansZ's Avatar
2004LeMansZ
Angry
Few areas in my Z rattle. The drivers side door, right corner dashboard, and center counsel near the gear shifter.
The driver side door has gotten worse ever since I had the power window motor replaced a week ago.
Old Feb 17, 2007 | 04:30 PM
black06z's Avatar
black06z
I get that problem everyday. Its mostly happening during bumps on the roads tho.
Old Feb 18, 2007 | 02:20 PM
LSRoadster's Avatar
LSRoadster
|dg
Any chance you can take the time and explain howyou got the skin off. I cant seem to figure it out.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
