Problem Starting the Engine
Old Feb 17, 2007 | 12:57 PM
slackjaw's Avatar
slackjaw
Default Problem Starting the Engine
Does any one else have this problem? I sometimes try to start the Z and nothing happens. I have to keep pushing in the clutch over and over to get it to "catch". It's not battery related and I have the clutch fully engaged but it's like there is a sensor in there that allows the car to start only when the clutch is fully depressed. It seems like that sensor is bad. I see all of the standard problems here that we all seem to have but haven't heard of this one yet. My car is an 03 Track w/ 36k miles so all of these little nagging problems are really annoying. If any of you guys have the fix for this please chime in but it looks like a trip to the stealership is in my future.
Old Feb 17, 2007 | 01:02 PM
Russ@Z1's Avatar
Russ@Z1
I've had a similar occurence in my Z last week. I tried two or three times with nothing happening. I stepped the clutch a few times to no avail. Next, I used the remote to lock the car and turn right back around and unlock the car. I tried to start the car again and it worked perfectly.
I came back to the car later that night and it did the same thing, but i was able to step the clutch pedal a couple times and it started right up. Sligthly annoying, but it hasn't happened since.
Old Feb 17, 2007 | 01:17 PM
Ztalker's Avatar
Ztalker
the pressure switch behind your clutch pedal is probably worn out. It happened to me three times last month, i had to press the clutch a couple of times to start the engine. i sprayed a little WD-40 on the switch about 10 days ago and i haven't encountered a single malfunction since....keeping my fingers crossed.
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
TDPrank
Sep 29, 2015 12:51 PM
Dymsi
Sep 29, 2015 11:32 AM
TDPrank
Sep 28, 2015 06:29 AM
