New Member quick ? "2200rpm Miss?"
Old Feb 21, 2007 | 06:14 PM
ThumperZ's Avatar
ThumperZ
Default New Member quick ? "2200rpm Miss?"
I just picked up a 03' 350z. I'm loving it. It is a black w/ black leather touring edition. The car drives and runs perfectly except I have a slight miss/stumble. When i'm driving I can only feel it in first gear but when I rev it slowly it will climb evenly untill right around 2200rpms then stumble for a few seconds and then climb on. I just replaced the spark plugs and did the tranny, diff, and engine oil. Other than that its stock. And help would be greatly appreciated thanks.
Old Feb 21, 2007 | 06:19 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Any chance you bought this car and it was previously modded?
Old Feb 22, 2007 | 03:38 AM
ThumperZ's Avatar
ThumperZ
I haven't seen any of the tell tale signs. Everything looks to be perfect and oem.
Old Feb 22, 2007 | 10:11 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
maybe it's just the variable intake cam or something.
if you were misfiring, you'd get a check engine light
Old Feb 22, 2007 | 10:24 AM
imjdoggie's Avatar
imjdoggie
Does it do this when the car is in neutral or only when you are driving?
Old Feb 22, 2007 | 12:40 PM
ThumperZ's Avatar
ThumperZ
It does both in neutral and while driving. But it is more noticeable in neutral and it only does it in first accelerating slowly so light load.
I have seen many cars have a small to moderate miss and not have the check engine trigger. I've been a mechanic for 7yrs. I just finished putting on my motordyne intake spacer and i'm going to go hook up my solus engine scanner and see if I can figure anything out. Any suggestions would be appreciated.
Old Feb 22, 2007 | 02:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'd just put the car up on a dyno with air/fuel. you'll definitely see something if it's missing
sales@czp
Sep 23, 2019 03:30 PM
Jambo016
Sep 16, 2016 01:08 PM
Tochigi_236
Sep 27, 2015 03:40 PM
