Drive Belt - When to Replace?
Old Feb 27, 2007 | 10:43 AM
jbyrne1's Avatar
jbyrne1
Default Drive Belt - When to Replace?
I brought my 03 350z touring 6spd in to the dealer at around 46k miles. They are saying that the drive belt needs to be replaced. I talked to a couple other car guys and they said that they were surprised.
Is it time to have it changed? How much does it usually cost?
Also, there is a high pitched whine coming from the engine at idle. I don't notice it as much as the engine rev's. Is this related?
Old Feb 27, 2007 | 10:46 AM
THE TECH's Avatar
THE TECH
Just check the belt for wear and go from there.
Old Feb 27, 2007 | 11:29 AM
Tayzzer22's Avatar
Tayzzer22
I don't remember exactly how much it cost.. But its damn expensive.. All I remember is that I was walking a little funny afterwards..
As for timeframe.. I believe its 60K? 47K does sound early..
Old Feb 27, 2007 | 02:17 PM
DavesZ#3's Avatar
DavesZ#3
I believe the standard maintenance at 30K miles calls for the replacement of the belts. Mine have 24K on them and I already notice some cracking of the ribs so I'll probably do it in the next month or so.
Old Feb 27, 2007 | 02:18 PM
DavesZ#3's Avatar
DavesZ#3
The belts themselves cost about $30 for the pair. It's not that hard to change them yourself. The dealer shouldn't charge for more than an hour ($75) of labor.
Old Feb 27, 2007 | 02:21 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Belts are EXTREMLY easy to change yourself!! If I were in your area, i'd do them both for you for a few beers and BBQ. Badda Bing.
Old Feb 27, 2007 | 02:23 PM
Tayzzer22's Avatar
Tayzzer22
Wow! I must have been taken! It was on my last car, an acura Type-R and I could have sworn that it cost something like $500-$800! Or maybe that's what it came out to be in addition to the stuff I was already having done? It was a while ago.. The car was stolen and that's when I met the new love of my life.. The FairLady!
Old Feb 27, 2007 | 02:26 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
No way in hell regular drive belts can cost that much. Even the timing belt comes out cheaper. You must have had other things done to it.
Old Feb 27, 2007 | 02:40 PM
DavesZ#3's Avatar
DavesZ#3
You're thinking of a timing belt. The Z doesn't have a timing belt, they went back to the old-style timing chain that doesn't require replacement.
Old Feb 27, 2007 | 02:44 PM
Bevo's Avatar
Bevo
+1 i just checked the maintenance guide it says change every 30K miles.
Old Mar 10, 2007 | 08:18 AM
djbit's Avatar
djbit
Changing my belts today....seems easy enough. 30 bucks for the belts. Not bad.
57K miles...I see cracking.
Old Mar 10, 2007 | 06:38 PM
n8vz's Avatar
n8vz
sounds like a good DIY write-up
Old Mar 15, 2007 | 02:23 PM
shinkuu's Avatar
shinkuu
ne1 in san diego can show me how to do this? what else needs to be done at 30k? i have 20k miles and a lot of them are hard track miles. i want to stay on top of the maintenance schedule
Old Mar 15, 2007 | 08:15 PM
Bevo's Avatar
Bevo
you can take a look at your maintenance guide booklet
Old Mar 16, 2007 | 12:42 PM
hooman6mt's Avatar
hooman6mt
Is there a write up for this? I've searched but didn't find anything
Old Mar 16, 2007 | 12:58 PM
Ztalker's Avatar
Ztalker
loosen only four little bolts to remove the old belts, install new belts and adjust tension. Not too tight, just tight enough so that its not making any noise. Re-adjust tension in a week or so as needed.
Old Mar 18, 2007 | 04:38 PM
hooman6mt's Avatar
hooman6mt
do you have to lift the car to loosen the bolts, or can I do it from the top?
Old Mar 18, 2007 | 04:46 PM
Nic@CiNcity
There is NO WAY you can looses those bolts from up top. Jack it up. It will only take a few minutes.
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
Mattg350z
Oct 2, 2015 06:51 AM
samansharif
Sep 25, 2015 12:31 PM
