Brake Bleed Question for OEM Brembo
Old Mar 5, 2007 | 11:32 AM
DMK's Avatar
DMK
Question Brake Bleed Question for OEM Brembo
Do the Brembo's have two bleed nipples? One on the front of the caliper and one on the rear. If so, which one do you bleed? If not, where is the bleed nipple located. Thanks.
Old Mar 5, 2007 | 03:03 PM
Scarab440's Avatar
Scarab440
Originally Posted by SMarinoZR
Each side of the Brembo caliper have a bleed points. Start with the one on the inside of the caliper first and finish with the one on the outside. Don't forget to lightly tap each side of the caliper with a rubber mallet to dislodge air bubbles.
+1 good answer...
Old Mar 5, 2007 | 05:18 PM
DMK's Avatar
DMK
Thanks. Everything went well.
Old Mar 6, 2007 | 04:33 AM
Kolia's Avatar
Kolia
I'll add this:
Push the pistons all they way back with the corresponding bleed valve open to push the trapped air bubbles out.
Old Mar 6, 2007 | 05:51 AM
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by Kolia
I'll add this:
Congrats on the Civic, what happened to the Titan you had?
Old Mar 6, 2007 | 06:27 AM
Kolia's Avatar
Kolia
Got traded for the Civic...
The amount of "truckwork" I did didn't justify the 35k truck with the 300$ fuel bill a month. Instead of towing the Z to the track, I'll just buy more tires and drive it there.
It was a nice truck thought...
Old Mar 6, 2007 | 08:33 AM
spacemn_spiff
Gotcha, Civic should be a good daily driver, at least more fun than Corolla.
JjL
East Canada
Jun 12, 2019 03:04 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Mattg350z
Oct 2, 2015 06:51 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
