Window Motor Issue ???????
I Need A Passanger Window Motor Where Can I Get One Besides The Dealerships. I Live In Key West And They Will Rape You A New One?????
And Any One Know How To Get Ride Of The Grease Strek On My Window When It Gose Up And Down???????????????????????
Do a search. I'm not sure about the grease streak but I know there's a DIY for the window motor in here somwhere. My motor went out last summer, cleaned it out and is still working perfectly. Saved me a good chunk of change.
+1 on the window motor write up. But for somereason my window doesn't move that extra bit to seal the car. When I close the door, it just stays there. Anyone know how to set the window limit?
Originally Posted by Ztalker
the dealer will reset it if your car is still under the 3yr/36kmiles warranty.
My window motor went bad bout 2 months ago. It wouldn't go up. When I was able to get it up after 1 week. it didn't close completely to when u shut the door it goes up a bit more. So i had a stereo system place check it for me, for $20. they took the window motor and hit it a couple times, and fixed it lol. Ever since, my window works fine. up and down and close when the door is shut. kinda weird...
There is a reset procedure TSB for the motor. cleaning helps
You can try to clean the felt with a degreaser when the door cover is off.
If you need a motor, pm me
I am in Fort lauderdale
