Help!!!! Asap
Old Mar 31, 2007 | 05:59 PM
RobertH's Avatar
RobertH
Default Help!!!! Asap
i was going down the road a little while ago and i was going around a corner and the car died. so i let out the the clutch hoping it would crank back from rolling in gear. it wouldnt start so i pulled over. well my gas light just came on an my gauge said i still had 40 miles. i put gas in it hoping that was the problem but it still wouldnt start. cant someone give me some advice please?? by the way i have a 2003 track model wit full boltons
thanks
robert
Old Mar 31, 2007 | 06:01 PM
VN_350z's Avatar
VN_350z
i think it's your engine. That's all i can tell. LOL
Old Mar 31, 2007 | 08:21 PM
Sean's Avatar
Sean
crank sensor?
Old Mar 31, 2007 | 09:15 PM
RobertH's Avatar
RobertH
thanks for the idea about it being the engine i was checking the tire pressure for a minute lol no but for real it turns over fine and someone else told me about the crank sensor what would it do if it went out? and the only other thing i can think of is the fuel pump?
thanks
robert
Old Mar 31, 2007 | 09:17 PM
diwun67's Avatar
diwun67
What CEL codes are you getting?
Old Mar 31, 2007 | 10:07 PM
RobertH's Avatar
RobertH
another problem..im not getting any cel codes
Old Mar 31, 2007 | 10:13 PM
Sean's Avatar
Sean
dead ECU? is it testing ?
Old Mar 31, 2007 | 10:18 PM
hwcustoms's Avatar
hwcustoms
Is it trying to turn over or do you get nothing at all?
Old Mar 31, 2007 | 10:32 PM
RobertH's Avatar
RobertH
it turns over just fine like it wants to start, but it just wont start everything else seems fine.
Old Mar 31, 2007 | 11:40 PM
RobertH's Avatar
RobertH
what do you mean is it testing. everything seems to work on the car except the engine wont start. anyone heard of problems wit the fuel pump?
Old Mar 31, 2007 | 11:49 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
can you hear your fuel pump? ive also heard of the mass air wires rubbing on hoods w/cai when not positioned right. first thing to do is check all fuses and relays though.
Old Mar 31, 2007 | 11:56 PM
RobertH's Avatar
RobertH
couldnt really hear the fuel pump bc i was on the side of the interstate. i checked the fuses but what an where are the relays u talk about??
Old Apr 1, 2007 | 12:22 AM
ARMSTRONGARMS
i believe they are in the fuse block under your battery cover? your hopefully still not on the side of the interstate, so can you hear your pump kick on when you turn on the ignition????
Old Apr 1, 2007 | 05:27 AM
RobertH's Avatar
RobertH
i brought it to a friends house last night. im goin to go over there today since i have some light now an check some things out.
Old Apr 2, 2007 | 08:21 PM
RobertH's Avatar
RobertH
well nissan worked on the car today. they tried to connect to the computer and tell it what to do. they said the ecm (engine control module)/ecu acted like it wasnt even hooked up. they said they didnt have an explaination for that so they ordered me a new ecm.
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
