Rattling Noise Inside Trunk Hatch!!?!?
Old Jul 27, 2007 | 09:54 AM
  #61
DRFTER_Z's Avatar
DRFTER_Z
bump for some one to come up with a permanent solution for this annoying noise.
Old Jul 27, 2007 | 01:54 PM
  #62
usmanasif's Avatar
usmanasif
I have the same rattle (the only one in the entire car). Since the hatch lid itself sits almost entirely on top of weather stripping which acts as a cushion, it can't be the hatch metal itself. Has to be the trim piece. If it is the trum, inserting a few tiny tightly folded pieces of paper (no wider than the nail on your pinky) between the trim and the hatch should provide enough cushion to stop it. I am going to give it a go this weekend and see what happens.
Old Jul 28, 2007 | 08:16 PM
  #63
Blazemaster's Avatar
Blazemaster
you guys should take a look at the DIY section every once in a while. I think most of the fixes in there can be performed by just about anybody.
Old Jul 28, 2007 | 09:23 PM
  #64
Amiricanmade's Avatar
Amiricanmade
Same problem here...i have stock cat-back. It sounds like it's coming from the left rear hatch/seatbelt area, its likea ding ding ding when i go over bumpy roads, but you can only hear it when the car is warm
Old Jul 28, 2007 | 09:29 PM
  #65
Amiricanmade
Danm it...lets all get together, write a danm letter to Nissan and ask for them to fix this!!! This noise makes me mad!
Old Jul 28, 2007 | 10:24 PM
  #66
Socalbreeze's Avatar
Socalbreeze
I notice this noise as well...especially on uneven pavement. My car is not lowered nor does it have an aftermarket exhaust. Still can't figure out where the heck the noise is coming from. Can it be the rear strut bar?
I'm going to let WCN take a peek at it. Will let you guys know the results.
Old Jul 30, 2007 | 04:48 PM
  #67
Chad68's Avatar
Chad68
Originally Posted by Chad68
I love quoting myself.
I added a second thin shim and the noise has once again gone away. I noticed that when I removed the catch to install the 2nd shim, that one of the 2 screws was not as tight as the other one, Even though I torqed the **** out of both screws, it still loosend a tiny bit, probably because the shim got compacted. So I added the second shim, so if or I should say when it starts doing it again, I'm just going to try to re-torque the screws and see if that's what caused it. If that's what it is I'll then try adding loctite to the threads.
And if those don't work then I'll push it off a cliff.
Well that didn't work. SO I removed the plastic hatch cover and drove around for a few minutes and didn't hear anything, so I'll leave that off for a while and see how that goes.
NICE CAR!!!!
Old Aug 31, 2007 | 12:00 PM
  #68
Mr. Famouz's Avatar
Mr. Famouz
UPDATE:
Just letting you guys know, I did end up going through a lawyer for the lemon law. Although Nissan wont buy the Z back, they are gonna give me an alright settlement, close to $3,000. It'll do I guess...
Old Aug 31, 2007 | 01:16 PM
  #69
350Z84's Avatar
350Z84
Wow, sweet deal! We should file a class action!
Old Aug 31, 2007 | 05:37 PM
  #70
Chad68's Avatar
Chad68
WOW where the Hell is my 3 grand haha.
I removed the plastic hatch cover alltogether about a week ago and I haven't heard the annoying rattle. Only when I hit a large bump do I hear any type of noise from the hatch and it's not very often. I still say it sounds like the latch.
So now I'm thinking MAYBE it's the plastic hatch cover and not metal or possibly the metal push clips on the cover. Sometimes the noise sounds metalic and sometimes it almost sounds like plastic.
If the plastic is cold it could sound more like metal and when warm sound more like plastic?? Dunno. So I'm going to use silicon on those pink plastic push tabs to eliminate them form flopping around and run sticky soft foam tape (not double side tape) along all the plastoc hatch covers edges and insulate the metal push tabs and see WTF that does.
I'm not ready to give up yet but would still like my 3 grand
Old Sep 16, 2007 | 10:03 AM
  #71
phreaktor's Avatar
phreaktor
Design Engineer
It's the metal clips that hold the plastic parts to the trunk lid. Make sure all of the panels are completely seated. It did the trick for me.
Old Sep 16, 2007 | 10:29 AM
  #72
cdoxp800's Avatar
cdoxp800
Ok. I had the same noise. I searched for it. Mine only came in to play at speeds greater then 50 mph.
Well two weeks ago I had the Z in a rack.I found the FLOOR SIDE FAIRING on the drivers was missing one of the two nuts.
See attached
Maybe this my help someone
Chad
Old Sep 28, 2007 | 02:44 PM
  #73
van46's Avatar
van46
Default same problem here:(
i'm going to try to explain it well but my english isnt that greateverytime i turn a little fast its like they throw a rock in to the backwheel on the passenger side but there is never a scratch on the car!!!is this the same kind of sound you hear
the sound is really driving me mad cause i al ready had the same problem on my MB clk230but now i'm a man on a mission and i will find it.tomorow i going to check it all out with the information you have me in the topic and i will let you now
thx
and good luck everyone in finding the problem
grtz
Old Sep 28, 2007 | 02:52 PM
  #74
cheshirecat79's Avatar
cheshirecat79
Originally Posted by mndthegap1
also make sure the spare is tight if its loose it may be rattling.
I bet this is what the problem is. check your spare and the associated tools. It may sound like the strut because the sound is bouncing off the window.
Old Sep 28, 2007 | 02:56 PM
  #75
van46's Avatar
van46
its not i'm stupid and now anything about a car but can you translate spare or show me wich ^part you mean
grtz
Old Sep 28, 2007 | 02:57 PM
  #76
van46's Avatar
van46
its not i'm stupid and now anything about a car but can you translate spare or show me wich ^part you mean cause i'm dutch and its not so easy
grtz
Old Sep 28, 2007 | 05:09 PM
  #77
cheshirecat79
Spare tire, as in pull up the carpet and check to see if your spare tire and tire changing tools are properly secured.
Old Sep 29, 2007 | 02:10 PM
  #78
van46's Avatar
van46
already checkt
Old Oct 12, 2007 | 10:51 AM
  #79
chadalac350z's Avatar
chadalac350z
Originally Posted by HIGHTECHZ
After I put in my exhaust, I got the rattles too. I think I have narrowed it to the plastic trim on the hatch itself.
I bought a small vacuum the other day and it was a tight fit, pushing against both the floor on the bottom and the hatch on top. Not a single sound or vibration on the way home. I checked it out and the box wasn't touching any of the sides or panels, just the floor and the hatch. I have some sound deadening I will try and get back to this thread and let you know how it goes.
Anyone else have this problem with the trunk rattling? It sucks!
Try holding the 3rd brake light cover when you hear the noise that was my problem i wedge it to stop sound
Old Oct 12, 2007 | 11:03 AM
  #80
ANXIOUZ's Avatar
ANXIOUZ
+1. I wedged some foam under the sides of my center light and it solved my rattling.
