Wheel Bearing
Old May 9, 2007 | 01:33 AM
D0M1N4710N2's Avatar
D0M1N4710N2
Default Wheel Bearing
For the past week my drivers side front tire has been making this crazy grinding/screeching sound, kind of like the one your brake pads make when their going out. I put new pads on last month, so there's nothing wrong with those.
It does it really bad when i'm making a sharp turn, like pulling out of a parking spot or something, and you can't really hear it past 35MPH.
Anyways, i've talked to a few people and they said it could be my wheel bearing. They said it could've gotten wet and rusted, or just straight up died on me.
Now, down to the point. Does anyone know where I could purchase a wheel bearing for that tire if it's the problem, and also would anyone like me to try and record it with my phone? It could be something else, I dunno. Any input is greatly appreciated. Thanks!
Old May 9, 2007 | 01:40 AM
blasian's Avatar
blasian
When my wheel bearing went bad, it was louder as I picked up speed. At 70, I could barely hear a passenger talking. It sounded more like a roaring noise though.
Old May 9, 2007 | 03:26 AM
Firehawk's Avatar
Firehawk
Check your brakes. If something is loose, it can make sounds like that.
Old May 9, 2007 | 11:56 AM
krazi3m3's Avatar
krazi3m3
I had a wheel bearing problem just recently and heard it at 40+ mph and left turn made it louder...I have an 06 so I was covered by warrantee and boy once they replace both my front wheel bearing it felt like I just bought the car the steering and the driving was soooo smooth
Old May 9, 2007 | 02:51 PM
DavesZ#3's Avatar
DavesZ#3
You might be interested in this thread....
https://my350z.com/forum/autocross-road/270456-beware-03-and-04-guys-front-bearing-wear.html
Old May 9, 2007 | 04:21 PM
rotaryrocket7's Avatar
rotaryrocket7
When you put weight on the wheel that's making the noise it should get worse if the wheel bearings going out. The post that Dave referenced is interesting... That usually doesn't happen. I would check the brakes to see if you may have a rock or something inbetween the pad and rotor before deciding that it's the bearing.
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
