goodbye 3rd gear
Old Apr 28, 2003 | 08:25 AM
pearl350z's Avatar
pearl350z
Default goodbye 3rd gear
anyone else have any tranny problems, synchros i guess are screwed, 3rd i almost completely gone. going back to the dealer tommorow.
Old Apr 28, 2003 | 10:13 AM
ares's Avatar
ares
Veteran
none here, always gonna have the bad apples, theyll replace the tranny for you. too bad that you have to deal with the hassle, but itll get fixed.
hope you didnt beat on it or anything, I donno if you can screw up synchros through improper use....
Old Apr 28, 2003 | 10:16 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Someone's had their tranny replaced twice now (yup, that means he's had three total!). From what I've heard, Nissan's been pretty good about replacing trannies like that.
My husband's 2000 Camaro Z28 had to have it's tranny replaced once when he first got it. It's just something that happens to some cars, but it really sucks when that car is yours. Hope they take good care of you!
Old Apr 28, 2003 | 11:21 AM
ares's Avatar
ares
Veteran
Id be very suprised if the design changed.... just a matter of getting a properly built one, a few arent up to spec. doesnt mean you rebuild the thing, you just try and make the line more accurate at building the correct design.
Old Apr 28, 2003 | 03:54 PM
articfury's Avatar
articfury
Charter Member #55
My second transmission is failing as well. Steve Kaufman (Raceboy) has had two trannies, a new clutch/flywheel, and driveshaft, IIRC. Not to mention several others that have had similar problems. I don't know that we can say one way or the other if this is a design problem or a build issue. We have very little real data, just a lot posts here and there about individuals having problems with this gear or that. Nissan seemed to think that the clevis pin was to blame, but that didn't solve the problem in my case.
I also wonder if the throw out bearing sound that many are complaining about is related to the tranny problems. My car has made the sound at varying degrees of loudness since I got my car.
JD
Old Apr 28, 2003 | 05:59 PM
dwnshift's Avatar
dwnshift
We have gone through 3 rebuilds on our race car. Each race we have replaced the 3/4 syncos, 3rd main gear twice, and the 5/6 shift fork. We have just received Nissans new updated 3/4 syncros from Japan.
Unfortuneatly we will not be using them this time ...instead we have my street car gearbox in there becuase the parts did get here in time ................
We installed new 3/4 syncros last rebuild and actaully put a ton of time on it. It felt notchy but we put about 8 hours of track time on it at Homestead and about another 7 hours of track time at Mid Ohio on the gearbox. We opened up the tranny to find the 3/4 syncro was just about completely gone.
Nissan is working very hard on this issue and the 5/6 shift fork. We are able to put alot of race time/ life time wear on a gearbox in a short amount on actual time.
Old Apr 28, 2003 | 08:13 PM
zogan's Avatar
zogan
I just got a new one last week, the dealer didn't even take it for a test drive. They know its a problem, they should order one for you, but this will blow your mind, there are so many being used, that they are on back order, so it will about 2-3 weeks before they can get one for you.
Old Apr 28, 2003 | 08:48 PM
Slexis200's Avatar
Slexis200
i think its more than a few bad apples...... i think were growing a tree
Old Apr 28, 2003 | 09:37 PM
elektrik_juggernaut's Avatar
elektrik_juggernaut
This whole thing wouldn't be so bad if they would just admit fault.....if they have to recall, then so be it......but i'm tired of getting fed horsesh*t.......the Clevis Pin thing that they're claiming is the culprit, is an outright lie.....if my Clevis Pin was the wrong length, i would grind every gear, not just third....i hear my synchros dying a little bit every day......it's a simple lubrication problem....but they won't admit that....better to say that a little pin is bad, then the whole frickin tranny
Old Apr 29, 2003 | 03:21 AM
dwnshift's Avatar
dwnshift
I am not a tranny expert but .....what I was shown looked like a couple of differnt things. The syncro when it starts to wear down doesnt lock onto the main gear..........
We def. had better luck with Mobil 1 race gear oil than Valvoline synthetic tranny oil.........
5/6 shift fork looks like a lubrication issue.
This is just our observations on our gearbox that we have been running.
Old May 1, 2003 | 08:34 AM
barnicleboy's Avatar
barnicleboy
Downshift, how do the new synchros that nissan sent you work? Are they wearing prematurely?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
