Do I need to take the pass. fender off to replace my windshield wiper fluid line?
Old Jun 11, 2007 | 11:38 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Default Do I need to take the pass. fender off to replace my windshield wiper fluid line?
Hey guys anybody here knows where and how the rubber line for the windshield wiper runs? Mine for some reason snapped off near the battery (Water runs out to the side of the car instead of to the wipers) and it appears I need to change out a new line. Unfortunately I can't tell if it runs under the car or through the fender to the reservior. Anybody know if if I need to take the fender off, can get to it from under the car, or through the plastic fender cover on top of the wheel?
Old Jun 11, 2007 | 03:42 PM
JDMFairladyZ33
Bump...anybody?
Old Jun 11, 2007 | 07:09 PM
PDX_Racer's Avatar
PDX_Racer
It's hard to tell from the FSM...
1. Remove clip and pull out washer tank inlet.
2. Remove under cover.
3. Remove fender protector. Refer to EI-21, "FENDER PROTECTOR"
in “EI” section.
4. Remove front bumper fascia. Refer to EI-14, "FRONT
BUMPER" in “EI” section.
5. Disconnect washer pump connector.
6. Remove washer tank mounting bolt and nuts.
7. Remove washer tube, and remove washer tank from the vehicle.
Old Jun 11, 2007 | 07:14 PM
JDMFairladyZ33
in “EI” section.
Thanks for posting this. The pics from the service manual doesn't help either but looks like from your instructions I need to take the front bumper off and the black plastic cover in the wheel well. I don't have a problem with at except that everything looks to be hidden under the fender. I've never taken the fenders off so I don't know what it looks like underneath or how difficult it is to do.
Sleeper01's Avatar
Sleeper01
dont remove it.....buy the t shape thing forgot what its called...but mine snapped off too i thought i needed a new one also...but its a plastic connecting thing...it just connects both tubes back together
Old Jun 11, 2007 | 07:16 PM
Sleeper01's Avatar
Sleeper01
i know i didnt really explain it to well but i did it to mine and it works. I would take a pic but my car is too far away..
Old Jun 11, 2007 | 07:22 PM
drivenCSZ's Avatar
drivenCSZ
did you take off all the plastic peices around the battery?
i swear you can see the line and where it goes from there. i might be mistaken though. and of course if you take the front bumper off, theres access.
Old Jun 11, 2007 | 07:28 PM
JDMFairladyZ33
I took off the plastic piece around the battery and followed the line. You know how our batteries sit in a little square like area made up of the bulkhead? Well the tube broke off as it enters the top near the firewall and I can't find the other side. I am assuming the other side broke off and fell down the hole under the fender. The motor is still pulling the fluid but it just exits out the side on the the ground near where the fender meets the door at the front splash guard
Old Jun 11, 2007 | 07:32 PM
Eazzy's Avatar
Eazzy
No ---You can thread it through, of course take off the cowl covers and pull your bumper off or back
Old Jun 11, 2007 | 07:37 PM
JDMFairladyZ33
Okay I'll give that a shot this weekend. Probably have to take the wheel and lip off again.
Thanks sleeper I know what you are talking about, but my problem is I don't have the other side visible at the moment.
Old Jun 11, 2007 | 07:39 PM
Eazzy's Avatar
Eazzy
If you take your tire and wheelwell out you can do it
Old Jun 11, 2007 | 07:44 PM
JDMFairladyZ33
Yeah I'll try that first. I was just thinking if I could cheat or if it's easier to take the fender off instead...lol.. If I'm successful I might even write a quick DIY.
Old Jun 11, 2007 | 10:35 PM
spf4000's Avatar
spf4000
Taking the fender off is not too bad. You're already half way there if you take off the bumper cover and the fender liner. The only other piece you need to take off is the side sill as there are two bolts covered by it.
Justin100
Nov 25, 2021 06:26 AM
burglapfd
Dec 6, 2020 01:04 PM
kyin
Oct 15, 2015 05:54 AM
