synthetic oil changes
Old May 3, 2003 | 09:41 PM
pkc415's Avatar
pkc415
Default synthetic oil changes
If I change to synthetic oil, does that mean I don't have to change oil until every 12,000 or 15,000mi.? I think that's what BMW's maintenance schedules are.
Old May 4, 2003 | 05:13 PM
Z'd's Avatar
Z'd
You might get away with that. Personally, I change every 5-6K or so, even using synthetic.
If you stretched it beyond that, you would definitely want to look at the oil quality- and not just the oil level, when you check the dipstick. (and make sure you use a high quality oil filter)
Old May 5, 2003 | 06:11 AM
dr_gallup's Avatar
dr_gallup
While you can probably get good results using premium synthetics for up to 25,000 miles you will be voiding a portion of your warranty since the maximum recommended change interval is 7500 miles. You also need to observe the every 6 months schedule if you are not putting a lot of miles on your car.
BMW's service interval is determined by the ECU and is dependant on how you drive, a lot of highway miles in top gear will let you go farther than a lot of around town driving. I don't know their exact algorithym but I think it is both rpm and throttle position dependant and probably has a time out as well.
I'm using Amsoil and changing every 6 months even though Amsoil claims I could go a year. I'll probably only put 6 to 8 thousand miles on it a year.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
