Does anybody have IDLING problems with their car???
Old Jul 1, 2007 | 12:10 PM
typerjun's Avatar
typerjun
Default Does anybody have IDLING problems with their car???
Just recently my battery died out... I replaced the battery soon afterwards... Ever since I replaced my battery, I noticed that everytime I start my engine... my car sounds like it drops down....then picks back up... sounds like idling problems...but since I'm not an expert...I hate to assume things... Does anybody have this same problem??? I drive an '03 Nissan 350z... Is their a fault on this vehicle model year??? Please help...any advice would help as far as how to correct this problem...or if this problem is actually a serious problem or not... What part would be necessary for me to repair this problem??? Thank you guys and girls!!!
Old Jul 1, 2007 | 12:13 PM
typerjun's Avatar
typerjun
Default oh...forgot to mention...
Oh...I forgot to mention that my car is bone stock... sorry about that...
Old Jul 1, 2007 | 01:42 PM
Mazinger Z's Avatar
Mazinger Z
Is it still under warranty? Maybe try an ECU reset. You can find instructions on how on the Motordyne website.
Old Jul 1, 2007 | 01:46 PM
thefastestz's Avatar
thefastestz
Also there is a hose that goes to the plenum. Make sure its snuggly fit and isn't leaking. Could have been knocked loose. or something. It is right next to the battery compartment on one side and then connects to the plenum.
Old Jul 1, 2007 | 03:55 PM
typerjun's Avatar
typerjun
Default oh wow!!!
I will try that... thank you guys!!!
My trusted 350z members!
Old Jul 1, 2007 | 06:18 PM
typerjun's Avatar
typerjun
Default could having a dirty engine have any effect on the idling??
could having a dirty engine...have anything to do with the idling effect??? As in...somebody told me shifting too early ALL the time (approximately at 2.5ish) could cause that...
hmmmmmmmmmmmmmm
Old Jul 2, 2007 | 10:51 PM
thefastestz
being that you have a newer car, i wouldn't think so.
Old Jul 2, 2007 | 10:55 PM
thefastestz
Have you seen the idle improve as the car warms up. the car will idle a little higher when its cold. Just checking.
Old Jul 6, 2007 | 05:46 AM
live2themaxuk's Avatar
live2themaxuk
had same problem. clean the throttle body
Old Jul 6, 2007 | 01:56 PM
Tim@WestCovinaNissan's Avatar
Sometimes if the battery is disconnected/dead for a certain period of time the ECM will lose its idle program. The car may stall on startup or the idle might fluctuate because the ECM does not know where the idle should be set. Take it to a dealer and have them relearn the idle. Should take care of your problem. Hope that helps.
Old Jul 6, 2007 | 03:59 PM
typerjun's Avatar
typerjun
Default thank you guys
all great suggestions! thank you! I'll try them
Old Jul 9, 2007 | 09:51 AM
live2themaxuk
Mine did same, carbon deposits in throttle body slowly put idle out, but ECM learnt about it, as soon as i disconnected and reconnected, idle was low and wouldnt start without throttle when warm. cleaned out TB and butterfly valve with carb cleaner with batt disconnected. good as new
Old Jul 23, 2007 | 03:55 PM
Deezflip's Avatar
Deezflip
funny thing, i disconnected the battery on my G35 to work on the stereo and after i connected everything back together, the idle started acting up couple times. Shouldn't the ECM adapt and learn? Disconnecting the battery and reconnecting it is practically a resetting of the ECM.
pslamp32
Feb 8, 2017 09:07 AM
Mattg350z
Oct 2, 2015 06:51 AM
05UltraYellow
Sep 24, 2015 05:41 AM
PureR3d
Sep 10, 2015 06:23 PM
Darkspy
Sep 7, 2015 09:09 PM
