Z seems to lose power after 5000 RPMs..?
Old Jul 19, 2007 | 06:58 PM
kourosH's Avatar
kourosH
Question Z seems to lose power after 5000 RPMs..?
Hi all,
Haven't been on in a while, but i've come across a nervewrecking problem with my car.
For the past 2 months I started to drive conservativley inorder to save gas, so i would rarely go past 4500 RPMs. Normally shift at 2500 RPMs.
Now, i was driving recently and decided to gun it, but I noticed once my car gets passed 5000 RPMS, and up into 6000, my car suddenly jerks, and feels like no more power is being given to it. You can feel the power stop. I'm not letting go of the gas, the power just stops coming. I dont know why. This normally happens in 1st and 2nd gear. I havent tried it in the higher gears.
Any feedback or solutions are appreciated.
Thanks,
Kourosh
Old Jul 19, 2007 | 10:12 PM
Mazinger Z's Avatar
Mazinger Z
Maybe you need to reset the ECU, it adapts to the way you drive. I normally shift pretty early to conserve gas but I gun it from time to time just to keep the car on it's toes. Let us know how it works out.
Old Jul 19, 2007 | 10:16 PM
Nexx's Avatar
Nexx
thats messed up, even the VQ35DE doesnt usually lose steam until after 6200rpm or so.
Old Jul 20, 2007 | 11:15 AM
silverz239's Avatar
silverz239
Originally Posted by kourosH
Hi all,
Thanks,
Kourosh
i'm having the exact same problem. does anybody else have this problem? i tried letting it sit over night with the battery disconnected and it still does it. help!?
Old Jul 21, 2007 | 07:44 AM
kourosH's Avatar
kourosH
I'll have to test that out......thanks bugs.
To reset the ECU: does disconnecting the battery work?(like silverz said) Or do you have to pump the brakes? Or what?
Old Jul 21, 2007 | 07:55 AM
yoichi's Avatar
yoichi
Do any of you have led tails by any chance?? aftermarket tails or LED bulbs???
Cuz if you do, that can be a problem...
Old Jul 21, 2007 | 07:58 AM
fast kiwi's Avatar
fast kiwi
^^ really?? would like too know more about this...
Old Jul 21, 2007 | 08:09 AM
yoichi's Avatar
yoichi
https://my350z.com/forum/maintenance-and-repair/265217-problem-cruise-set-car-sluggish.html
If your cruise control also doesn't work, then you have the same problem that i did and some people in this thread. I had led bulbs in the rear and as soon as i returned to stock, the car ran perfectly fine. it was a issue with the voltage. hope this helps
Old Jul 21, 2007 | 09:48 AM
silverz239's Avatar
silverz239
hey man.... i just tried it out again last night. it seems to be working fine today. it hasn't given me that problem yet. i'm gonna wait a couple days before i make any conclusions though.
Old Jul 24, 2007 | 06:31 PM
silverz239's Avatar
silverz239
the problem still stands. any ideas anyone???
Old Jul 25, 2007 | 06:35 AM
yoichi's Avatar
yoichi
check if your cruise control is working
Old Jul 25, 2007 | 07:42 PM
silverz239's Avatar
silverz239
i'll check it out tomorrow... i do have the led tails. i can't remember if it started before i put the tails on??
Old Jul 26, 2007 | 04:42 AM
yoichi's Avatar
yoichi
Trust me, change it out to stock. Those damn LED's are the problem!!!
Old Jul 27, 2007 | 10:01 PM
silverz239's Avatar
silverz239
i checked the cruise control and yeah... it doesn't work. i'm gonna put the stock tails back on over the weekend. i'm gonna miss those led's though man.
Old Jul 28, 2007 | 08:09 PM
yoichi's Avatar
yoichi
Tell me how it goes and you better thank me!!! A six-pack will do
Old Aug 6, 2007 | 11:00 AM
silverz239's Avatar
silverz239
yup... the led was the problem. thanks yoichi.... if we ever meet, i'll bring the six-pack fo sho.
Old Aug 6, 2007 | 11:02 AM
Blu_Blur's Avatar
Blu_Blur
Kick-a$$ job dude!!!!!
Well-done!
Old Aug 6, 2007 | 11:34 AM
VO...'s Avatar
VO...
Administrator
Interesting. I'd like to know what it is about the LED's that cause the problem.
Old Aug 6, 2007 | 12:42 PM
Blu_Blur's Avatar
Blu_Blur
Must have to do with voltage interference with the ECU itself ORRRRR voltage interference with the MAF sensor.
Old Aug 7, 2007 | 07:07 AM
DrPhantum's Avatar
DrPhantum
I'm having the same problem... and yes... I have LED tail lights. I won't accept "change back to stock" as a solution. We must find a solution... and I believe that solution is a series resistor. What size? Let's figure that out. If the stock LED tail lights work, maybe somebody with the stock LEDs can look for a series resistor in their lamp and measure the resistance with a multimeter? Does this sound feasible? Pictures would be nice, too.
I bought a set of LED turn signals for my '04 Eclipse Spyder GTS, and resistors were recommended... but only because the lights would flash rapidly, indicating that the bulb was burned out. As it happened... the car thought that the bulb was burned out because of the change in resistance/current/voltage associated with the LEDs, which have different electrical properties. From what I remember in school... incandescant bulbs are big resistors, and Light-Emitting Diodes (LEDs) have a comparitively LOWER resistance. Hence the need for a series resistor to "simulate" the filament of the stock incandescent bulb.
Please, somebody help us find a solution. I heard mention of a resistor accessory that was being sold with LED tails somewhere... any more information about that? What size? What do they look like? If I'm going to install resistors, I want them to have a heatsink/environmental shield on them...
WHY DON'T THE LED TAIL LIGHT MANUFACTURES JUST INSTALL THESE RESISTORS AS PART OF THE LIGHT THAT THEY MAKE???
