Rev Meter got stuck
Old Jul 20, 2007 | 11:26 PM
kPaNdA350's Avatar
kPaNdA350
Default Rev Meter got stuck
Has this happened to anyone?
First time it happend to me. I was driving in traffic switching gears constantly, when the rev meter got stuck at 1k rpm. Got stuck for about a good 5 mins of driving in traffic, then twitched up to 2k rpm, did not even smoothly transition but suddenly jumped up to 2k rpm. After a while it began to work again.
Then it happens again for the 2nd time. It got stuck at 1k rpm again.
It's fine now and works perfectly. Don't know if it might happen again.
Should I get it checked out?
Old Jul 21, 2007 | 03:33 AM
wroby's Avatar
wroby
same thing happened to me a few weeks ago..
Old Jul 21, 2007 | 03:38 AM
flintgauge's Avatar
flintgauge
that used to happen to me all the time in my 1985 Toyota celica. It would stay high or low, or bounce up and down... it was weird. I just assumed it was due to the age of the vehicle (20 years old). Maybe the wiring on the tach is bad?
Old Jul 21, 2007 | 06:31 AM
Steve-O Z33's Avatar
Steve-O Z33
That, or keep dealing with it.
Old Jul 21, 2007 | 06:34 AM
zand02max's Avatar
zand02max
Happens a lot with the Roadsters when the top is down. When the sun hits it just right it sticks!
Old Jul 21, 2007 | 06:37 AM
fast kiwi's Avatar
fast kiwi
^ really??? thats wierd?
Old Jul 21, 2007 | 07:03 AM
HondaKiller's Avatar
HondaKiller
if it only happens spratically, i doubt nissan will be able to replicate it. Only time i've had problems with something like this, is after a gauge color change. Once you swap out the backing's and the needles their never the same. Sounds like you probably have a faulty circuit in your cluster. (watch for armor all, that will f*ck your electronics up over time from build up.)
Old Jul 21, 2007 | 07:40 AM
tecni's Avatar
tecni
Get one of those big Autometer tachs that go on te dash LOL sorry, never happened to me before.
Old Jul 21, 2007 | 09:42 AM
psunner's Avatar
psunner
yep, same thing happened to me around a month ago, but ever since it has been working fine.
Old Jul 21, 2007 | 12:48 PM
kPaNdA350's Avatar
kPaNdA350
Well my car is fairly new. Its only been a year and i have 7k miles on it.
Old Jul 21, 2007 | 12:50 PM
michaeljr6's Avatar
michaeljr6
the power of nissan
Old Jul 22, 2007 | 12:17 AM
kPaNdA350's Avatar
kPaNdA350
If it happens again, I'll most likely get it checked out.
Old Jul 22, 2007 | 02:00 AM
rb6sn's Avatar
rb6sn
Is your Z a roadster? I remember hearing that happens when the sun is on the tach too much
Old Jul 22, 2007 | 03:21 PM
tmak26b's Avatar
tmak26b
try checking the grounds on your car
Old Jul 27, 2007 | 02:07 PM
Gizmo0803's Avatar
Gizmo0803
this just happened to me yesterday for the second time...my car only has 4K miles on it and it's an '07. I called the service department at nissan and i scheduled an appointment for this saturday to get it checked out. I'll let you guys know what they tell me.
Old Mar 29, 2010 | 01:41 PM
karas..56's Avatar
karas..56
i had exactly the same problem today when i was driving with top down for a few sec.after that is working perfect .should i worried about that ?
Old Mar 30, 2010 | 12:33 AM
GHOST1207's Avatar
GHOST1207
Used to happen to me month after I got the car, it's normal. Posted a thread asking about it, if the sun stays directly on the tach for a good amount of time, it gets stuck for about a while. About 6 months into owning the car, bought it brand new, issue went away. IMO, must be all the heat that's created from the tach, light + black = heat, and the warmer weather. Wouldn't be surprised if mine started acting up, and I live in the desert.
Old Mar 30, 2010 | 01:12 AM
calin's Avatar
calin
It happened to me about 5 or 6 times so far and my Z is a coupe.
Old Mar 31, 2010 | 02:47 PM
karas..56's Avatar
karas..56
you are saying we should not worry about that ?but it wont cause us any other problem ?
Old Mar 31, 2010 | 06:37 PM
gregom's Avatar
gregom
happens to me too... direct sunlight on the center where the needle pivots. If I put my finger in a position to block the sunlight from hitting the needle, after a few seconds it starts working again.
I'm wondering if it gets too warm, expands, and is physically being prevented from moving. It is really annoying... i've been thinking about tearing the thing open and covering the pivot point of the needle with a black but heat reflective material.
