350z Passenger window???
Old Aug 14, 2007 | 12:40 AM
Chadro's Avatar
Chadro
Default 350z Passenger window???
I have Recently bought a 04 350z performance. when i lock my car sometimes my window automatically rolls down on the passenger side about 1/2 way. my friend told me that they have allot of electrical problems. has anyone else had this problem before?
Old Aug 14, 2007 | 12:44 AM
ASTIG_Z's Avatar
ASTIG_Z
is the car still under warranty? I had the same problem and they replaced my window motor without any questions.
welcome to the forums. there is alot of information on this site about our car. the search button is your friend! good luck!
Old Aug 14, 2007 | 12:54 AM
Chadro's Avatar
Chadro
yeah my car is still under warranty, i have to have them put a 02 sensor on today actually. so when you fixed the window motor did you ever have anymore problems with it? i will have them look at it today, Thanks man
Old Aug 14, 2007 | 12:57 AM
ASTIG_Z's Avatar
ASTIG_Z
no problem, havent had any issues with the window since the repair.
Old Aug 14, 2007 | 05:26 AM
HondaKiller's Avatar
HondaKiller
probably a malfunction with the unlock mechanism on your keyless entry. If you hold the unlock button for 3-5seconds it will roll down your windows.
Old Aug 14, 2007 | 06:56 AM
usmanasif's Avatar
usmanasif
Your motor's internal switches have failed; causing it to lose its memory. Mine did so at 6k miles. Dealership reset the motor first. When they failed again 2 weeks later, motor was replaced immediately.
Old Aug 14, 2007 | 07:26 AM
dan105540's Avatar
dan105540
Default been there done that
Easy reset problem.... you can find a sheet under the window problem from Nissan that explains how to reset it and how to take your door off. Did that and have since replaced a window motor too.. not hard at all. You have to reset the new motor as well....
Good luck
Old Aug 14, 2007 | 08:31 AM
VO...'s Avatar
VO...
Administrator
My passenger's side window is experiencing wierd problems also. Not the same as the OP, but along the same lines. When I click on the auto roll up , the window will roll up about half way then go back down. I have to hold the switch for it to roll up all the way. Is this also a window motor problem?
Old Aug 15, 2007 | 07:45 AM
PandaHater's Avatar
PandaHater
I have a problem too! It’s just my passenger side thought. When you open the door the window stays up in its sealed position so you can’t close the door without putting the window down, shutting the door and then putting the window back up from the other side. I guess it’s the motor too, but my car is not under warranty!!! So how much does the window motor cost?
Old Aug 15, 2007 | 08:36 AM
usmanasif's Avatar
usmanasif
Certainly. When the motor loses it's memory, it doesn't "know" where the window is when you roll it up or down. Your "anti-pinch" feature is likely kicking in when the window reaches mid-way, so it rolls back down. Resetting will fix it as long as you follow the procedure correctly (listed in TSB) but it may return. In that case, replacement is the only fix.
Siqcology
Sep 18, 2019 01:45 PM
Mattg350z
Oct 2, 2015 06:51 AM
CJs_Z33
Sep 18, 2015 12:06 PM
AP350z223
Sep 8, 2015 04:38 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
