vibration
so this weekend, i decide i am going to raise my car and install my cusco fron a arms, to correct the camber. after 3 hrs of trying to break my coilover loose, it wont budge, so i decide to just leave it at that height and install the camber arm anyways. since the car is up on jack stands, i do my oil change too.
immediately after, i finish installing and changing the oil, i drive off. and 10 minutes in while the oil is still cool. i have no problems. by the tuime i get home, there is a weird vibration( it almost feels like there is sand in the engine, very gritty and not smooth when i rev up).
I check my oil pressure gauge, everything is normal, engine temp is normal. While the car is moving i shift into neutral and let it coast. There is sudeenly no vibration. This rules out for me at least the idea that maybe the camber arm was coasuing it. Only when i push the gas, even slightly does the vibration come in. it also dimishes with higher rpm .
Any ideas what is wrong?
My freind thinks it might be the upper control camber arm bushing, vibrating with the frequency of the engine. therfore as i get on the gas, i start to hear it, while in neutral it doesnt make noise.
My friend also thinks its might be something having to do with the oil. maybe i put in too much?
Also after i drove home,. i can smell something burning coming from the engine bay, very slight but definitely there. I also blew a white or grey ploom of smoke ( keep in mind i do not have cats, i have test pipes and hks exhaust)
This is the breakdown. I drive to a friends house to install the camber arms and rear spc camber kit, also change my oil. before i install there, driving up, everything was normal. Once i install the camber arms front and rear and change the oil, all these problems start happening.
Your help is greatly appreciated
The problem most likely lies in something you did while either changing your oil or installing the camber arms. Either way double check your oil level and camber arms to make sure nothing is wrong.
FCallender
May 19, 2003 01:45 AM
jaxxxx
May 6, 2003 08:26 AM
