What does this sign mean? (pic inside)
Old Aug 27, 2007 | 12:35 PM
shaneel7861's Avatar
shaneel7861
Default What does this sign mean? (pic inside)
i just got this car from nissan showroom 2 weeks ago.. its a 2006, 44k miles on it.. and this sign popped up this morning.. i think it has to do something with oil? but the oil change is due on 48k
the speedometer this says SPI.. dont know whats that suppose to mean..
someone help me out thanks..
Attached Thumbnails What does this sign mean? (pic inside)-image_00095.jpg   What does this sign mean? (pic inside)-image_00096.jpg   What does this sign mean? (pic inside)-image_00115.jpg
Old Aug 27, 2007 | 12:38 PM
Tubbs's Avatar
Tubbs
You never looked inside the manual, did you?
blaukal's Avatar
blaukal
search is your friend. low tire pressure for the first two pics. I'm assuming this isn't a joke post to try to get a bunch of people in here flaming you...
Old Aug 27, 2007 | 12:45 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Yea def tire pressure. Its on in my car bc i guess im running 275 40 18s. Dont worry about it unless u have stock rims and tires.
Old Aug 27, 2007 | 12:46 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
either your tire is low on pressure or you don't have tps on your aftermarket rims.
that will light up for either
Old Aug 27, 2007 | 12:50 PM
RedBullRR's Avatar
RedBullRR
It just means your car will blow up in 54321......
Joking. Just means your tire pressure is off. I have after market rims with out the TPS on and the light only comes on after driving for about a hundred miles. Turns back off when i turn the car off though.
Old Aug 27, 2007 | 03:05 PM
Eazzy's Avatar
Eazzy
The Manual is your friend
Old Aug 27, 2007 | 03:08 PM
Tubbs's Avatar
Tubbs
What I find funny is that the OP took the time to take pics, get on the internets, start a thread, then manually upload his pics (probably after resizing them)... and he couldn't spare the 13 seconds required to look it up in the manual.
Old Aug 27, 2007 | 03:27 PM
Eazzy's Avatar
Eazzy
Im Appalled, Perplexed, and Disappointed
Old Aug 27, 2007 | 04:36 PM
shaneel7861
i did look in the manual but i couldnt find it... so i post it over here.. and ido have stock rims and tires.. so what do i need to do to get that sign off? (ill look in the manual too)
Old Aug 27, 2007 | 04:38 PM
blaukal's Avatar
blaukal
oh lord, shaneel. fill the tires with air. I want to hug you and tell you its ok. feed you a bowl of soup. give you a 10 dollar bill and tell you to not spend it all on candy.
Old Aug 27, 2007 | 04:44 PM
Tubbs's Avatar
Tubbs
you need to fill your tires with air, that's what.
Old Aug 27, 2007 | 04:51 PM
danisr1's Avatar
danisr1
Sleeps in 350Z
check your air next time you gas up, which looks like it will be soon
Old Aug 27, 2007 | 04:58 PM
shaneel7861
lolzz.. thanks for telling me.. now ill go to QT and get free air for my tires
Old Aug 27, 2007 | 05:05 PM
I1DER's Avatar
I1DER
Find out which tire needs air. Look in you manual to see how to rotate through the displays of your trip computer. It will show you which tire is low, but you usually have to be going over 16mph for it to give a reading on all tires.
Old Aug 27, 2007 | 05:06 PM
Sleeper01's Avatar
Sleeper01
maybe you picked up a screw too.....if you click the side button you could check your psi to see which one is low.
Old Aug 27, 2007 | 05:19 PM
shaneel7861
wat side button? i see PSI or PS1? in the speedometer thing (in the 3rd pic)
Old Aug 27, 2007 | 06:20 PM
usmanasif's Avatar
usmanasif
That is a butt-like sign. It has two meanings:
Whenever it comes up, you have to get out and moon the car.
The fuel prices are mooning you; that's why it is below the fuel gauge.
Old Aug 27, 2007 | 06:36 PM
Netko350Z's Avatar
Netko350Z
Quit screwing with the guy. That light really means the summer air in your tires is low and you need to switch over to winter air.
Old Aug 27, 2007 | 06:39 PM
blaukal's Avatar
blaukal
psi means pounds per square inch. it's referring to air pressure in the tire. which is low. so put more in. should be manageable.
