Why is my battery dead?
Old Sep 10, 2007 | 09:26 AM
Dui-Dan's Avatar
Dui-Dan
Default Why is my battery dead?
so i just went out to my car a few minutes ago to find that the battery is dead. it looks to be at like 11 volts right now. the engine turns over a few times and then i hear a rapid clicking noise, would this be indicitive of a dead battery (i havent killed the battery on my z yet)? no i didnt leave a light or anything else on. yes i tried to manually press the clutch button. i wont have a chance to jump it until my roommate gets off from work. it also had a hard time starting up once last week, where it cranked over a half a dozen times before starting. im wondering if this is an alternator or what havent noticed anything with the batteries voltage before. thanks
Old Sep 10, 2007 | 10:45 AM
Dui-Dan's Avatar
Dui-Dan
update: so the battery started within seconds of connecting the jumper cables... what gives, started up fine the second time, battery voltage back to normal....
Old Sep 10, 2007 | 11:11 AM
HondaKiller's Avatar
HondaKiller
you probably have dry cells in your battery. Once a cell goes bad on the battery the battery will not hold a charge. The clicking sound you are referring to is a dead battery. The jumper cables might have provided enough power to start your car, but i doubt the battery will hold a charge over night and will be dead in the morning. One of the cheapest replacements you'll do on the Z, get a new battery, dont stress everything else in the car out by having a near dead battery.
Old Sep 10, 2007 | 11:16 AM
stein's Avatar
stein
Battery's are like electronics, you get a bad one once in a while. If your car's is under warranty take it to the dealership. The wife's battery on a new car went after just 2 months, they give her a new one no questions asked.
Old Sep 10, 2007 | 11:23 AM
350NC's Avatar
350NC
I am having the exact same prob this morning, my car just clicked very rapidly and all lights came on, but it would not even attempt to turn over at all. I was running late for work so didn't have a chance to jump it either, so i do not have that much of an update, but if anyone could shed some more light onto whether or not that type of description could be something other than the batter let me know, thanks
I will try jumping it when i get home this evening though and provide an update as well
Old Sep 10, 2007 | 11:43 AM
cheshirecat79's Avatar
cheshirecat79
I wouldn't bother overanalyzing a simple problem. Batteries that don't hold a charge that somewhat new just need to be replaced. Go grab a battery with the same pole alignment and cold cranking amps and call it a day.
Old Sep 10, 2007 | 12:01 PM
VO...'s Avatar
VO...
Administrator
+1... Overanalyzing FTL.
Old Sep 11, 2007 | 09:09 AM
Dui-Dan's Avatar
Dui-Dan
yawp yawp.... bought a new battery, put it in and everythings good. thanks yall
Old Sep 11, 2007 | 09:39 AM
VO...'s Avatar
VO...
Administrator
Cool
Old Sep 12, 2007 | 09:19 AM
Ztalker's Avatar
Ztalker
no excuse for not having one of these in the garage, cheap insurance.
Old Sep 12, 2007 | 09:22 PM
roast's Avatar
roast
Attachment 161416
I have one. I usually use it for my lawn equipment though. The battery in my Z is 3 1/2 years old and still going strong... probably will replace it with a lightweight battery within the next year....
Old Sep 12, 2007 | 09:47 PM
VicPham's Avatar
VicPham
Lifetime Member
Attachment 161416
I have the exact same one like in the pic.
To the OP.... You should check your battery terminals. My friends 350z had the exact same problem. All he did was clean the terminal and called it a day. Now dont let the clean look on the outside of the terminal fool you. My friend had to disconnect all the way and clean the inside ring of the terminal.
Old Sep 13, 2007 | 11:59 AM
VO...'s Avatar
VO...
Administrator
Attachment 161416
I had one similar I had recieved as a Christmas gift from an ex. Too bad it refused to hold a charge after a couple years.
Old Sep 13, 2007 | 12:14 PM
Ztalker's Avatar
Ztalker
make sure you don't put it on the floor in the garage. It'll drain all the juices out. This one i got is over two years old and still holding the original charge.
Old Sep 16, 2007 | 03:37 PM
TSG-Z's Avatar
TSG-Z
I need some help here, not my weekend for sure! My buddy's G I'm using as a DD needed a new battery, went to go get one, tested it, worked fine went back out maybe an hour later it wouldnt turn over or anything! Upon further inspection I think the fuse connected to the battery may be blown, would that prevent the car from turning over? Thanks for your comments!
Old Sep 17, 2007 | 10:09 AM
VO...'s Avatar
VO...
Administrator
Thanks for the info, I never knew that.
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
Depravity
Oct 1, 2015 04:49 PM
OdesiTT
Sep 30, 2015 10:47 AM
Shane86
Sep 17, 2015 05:33 PM
