3rd Gear is Gone.....
Old Sep 28, 2007 | 06:24 AM
alpine's Avatar
alpine
Angry 3rd Gear is Gone.....
HeyaZ,
Last night on the way home, 3rd gear decides to go on vacation!
At the time, not doing aything of interest shifted into 3rd gear, no problem start to accelerate and I see the RPMS run up without any resistance and before I know it, it "popped out" of gear.
Never seen that before, but I figured I just somehow lazy shifted and tried it again, with the same response.
I'm assuming we're talking about bearing/synchro's here right?
Anyone been through this before this is my first....
Let me know,
Joe
Old Sep 28, 2007 | 06:27 AM
03Platinum350z's Avatar
03Platinum350z
Sorry man I got nothing here Hope everything turns out well!
j3ff
Old Sep 28, 2007 | 08:07 AM
HondaKiller's Avatar
HondaKiller
yeah, if it slips, then pops out of gear you have a bad synchro. You can probably have it realigned, but it will happen again. Temp fix to prolong your transmission replacement. Sorry to hear mang.
Old Sep 28, 2007 | 08:47 AM
I1DER's Avatar
I1DER
It's OK, you have five other gears you can drive in.
My guess is that it only pops when you ease off on the accelerator in third to where it would be rev-matched to go into 4th. If you drive with your hand on the shifter it will probably stay in gear until you shift, but that will eventually bug the heck out of you. Hopefully it is still under warranty.
Old Sep 28, 2007 | 01:01 PM
alpine's Avatar
alpine
I think you are right about when/why it pops out, obviously after the first couple occurences of this, I haven't been back to 3rd gear which is a bit of an issue on uphill onramps with someone behind me and I'm crawling....
Fortunately with the boost I can get more than enough momentum to make things look right otherwise... Although for obvious reasons, 3rd gear WAS my favorite gear....
Right now I am still under warranty and I am hoping the guys at Performance Nissan will take care of it for me.
I am also going to take advantage of the "down" or "up in the air" time and go forward with a new clutch, I have a "clutch thread" going on somewhere else ( https://my350z.com/forum/showthread....04#post4456504 ) if someone wants to help me out there.
Thanks!
Old Sep 28, 2007 | 01:18 PM
JCat's Avatar
JCat
It is not a bad sychro. 3rd gear is actually brazed to it's hub.
Z's with a lot of horsepower actually break this brazed connection.
I remember reading about this happening to some memeber here. I think there was some discussion about an aftermarket fix to this problem being necessary.
Perhaps someone can point you to the tread or forum member that has experiences this problem.
Found it......here : https://my350z.com/forum/showthread....light=3rd+gear
Old Sep 28, 2007 | 04:27 PM
alpine's Avatar
alpine
Thanks for the info here, I will be following up with the link. Can anyone else add to this concept?
(I've been to the thread)
Wow.. that wss damn interesting, I wonder if someone is actually going to solve this also it seems strange that we have gotten this far without this info.
Old Sep 29, 2007 | 02:57 PM
krnzzang84's Avatar
krnzzang84
I have the same problem, it is ok at normal drive but when i floor it to 55k to 6k rpm it always grins bad, I went to the dealer and they told me that they will swap my trans to new one!!!
Old Oct 6, 2007 | 05:57 PM
alpine's Avatar
alpine
Smile
Problem solved....
New 009 Trans and New Clutch.... went with the RPS Twin Disc Carbon!
Many Thanks to Performance Nissan, Again!
Thanks to Tim, Andy, Brian!
Joe
Old Oct 7, 2007 | 03:18 AM
malized's Avatar
malized
Originally Posted by alpine
HeyaZ,
Let me know,
Joe
hi joe, i had the same prob, it's realy the synchro's , i change the my stock clutch in same time and i change to '' SPEC CLUTCH SATGE 2+ '' fantastique clutch... before i was thinking from the clutch.... but no it was realy the 3rd gear grind... my friend have the same prob on the 5 gear, so its DEFAULT in the z as the front LEFT SPEAKER in the radio system.
good luck man
joe
Old Nov 13, 2007 | 11:40 AM
xav_350z's Avatar
xav_350z
its 100 % syncros....
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
