power steering noise when i turn the wheel
Old Sep 29, 2007 | 03:40 PM
Dan Ketch's Avatar
Dan Ketch
Default power steering noise when i turn the wheel
I recently changed my powersteering resavoir now, when, i turn the wheel it makes a horrible winding noise.
Old Sep 29, 2007 | 04:22 PM
BlueBallZ's Avatar
BlueBallZ
the only time that happened to me is when i had very little power steering fluid in my car =T this was when i had an audi a4 though
Old Sep 29, 2007 | 05:21 PM
Dan Ketch's Avatar
Dan Ketch
thanks for the input i will try pick some up tomarrow
Old Sep 29, 2007 | 06:01 PM
DavesZ#3's Avatar
DavesZ#3
Did you bleed the air out of the system?
From the FSM:
1. Stop engine, and then turn steering wheel fully to right and left several times.
CAUTION: Do not allow steering fluid reservoir tank to go below the low-level line. Check tank frequently and add fluid as needed.
2. Run engine at idle speed. Turn steering wheel fully to the right and then fully to the left, and keep for about three seconds. Then check whether a fluid leakage has occurred.
3. Repeat the 2nd procedure several times at about three seconds intervals.
CAUTION: Do not hold steering wheel in the locked position more than 10 seconds. (There is the possibility that oil pump may be damaged.)
4. Check generation of air bubbles and cloud in fluid.
5. If air bubbles and the cloud don't fade, stop engine, hold air bleeding until air bubbles and the cloud fade. Perform the 2nd and the 3rd procedures again.
6. Stop engine, check fluid level.
Old Sep 29, 2007 | 07:45 PM
seZy350's Avatar
seZy350
sounds like not enough fluid and got air into the rack. bring it to a shop and have it flushed out. thats my guess.
Old Sep 30, 2007 | 09:27 AM
Dan Ketch's Avatar
Dan Ketch
From the FSM:
genius
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
