Starting Issue
Old Sep 30, 2007 | 02:33 PM
Ruthless18x's Avatar
Ruthless18x
Default Starting Issue
I searched and found some similar problems but none exactly or with results. When starting my Z for the last couple days it has been really slow. I've had to keep the key turned for 5 seconds plus as it trys to turnover. Today I had to keep it cranked for 10 seconds to get it to start. Is it most likely the batter or could there be another common problem. I plan on just taking it to Nissan if I can't figure it out by tomorrow. Thanks.
Old Sep 30, 2007 | 03:28 PM
cheshirecat79's Avatar
cheshirecat79
how old is the battery
does the motor sound like its turning over normally
when you start it is there any smoke
Old Sep 30, 2007 | 03:46 PM
Ruthless18x
The battery is prolly almost two years old...yeah the motor sounds perfectly normal and no smoke.
Old Sep 30, 2007 | 07:40 PM
silverbullet_Z's Avatar
silverbullet_Z
sounds like you need a new crankshaft sensor... Are you throwing a code??
Old Sep 30, 2007 | 08:18 PM
Eazzy's Avatar
Eazzy
Hard starts ---Battery----Apples and Oranges, though at 2 yrs your close to new Batt Time---Could very well be CS, or pump pressure---There will be a code. Your killing your starter
Old Oct 2, 2007 | 02:45 PM
Ruthless18x
Was the battery. Bought a Optima yellow top and everything is fine. Thanks.
Old Oct 2, 2007 | 10:08 PM
Z_crazy's Avatar
Z_crazy
lucky, one lasting that long in AZ is really good and almost insane! mine only lasted a year and 1/2
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
