No start issue??
Old Oct 7, 2007 | 07:53 AM
SilverZ 03's Avatar
SilverZ 03
Question No start issue??
Weird thing just started with my Z. I put the key in the ignition and turn it to start, nothing happens. The dash lights come on, radio work, headlights work, wipers, etc... does NOT make a clicking noise or any other noise..just nothing. If I keep trying it a few times, eventually it starts. Seems like a sensor to me. Any suggestions???
Old Oct 9, 2007 | 03:12 PM
omega6's Avatar
omega6
what year is your car and miles?
1. clean your battery (connectors)
2. '03-'04 Z's have a tendency of not starting due misreading of the small chip in your key. Only occurs for me when, the "stock" alarm light stays on when I insert the key. (i wrote a long page about this before... "search")
simple fix: just re-alarm and un-alarm your car if u have a stock keyless remote entry or if that red light does stay ON, resert key till it turns off.
you can search this problem in the forums, goodluck.
Old Oct 9, 2007 | 06:40 PM
cheshirecat79's Avatar
cheshirecat79
Is it a manual transmission? Sounds like the little switch underneath the clutch pedal is going bad.
Old Oct 10, 2007 | 11:29 AM
Ztalker's Avatar
Ztalker
^^Yup, most likely^^sticky switch.
happened to me a couple of times earlier this years. i sprayed a few drops of W-40 at that pressure switch under the clutch pedal near the fire wall. BINGO...problem fixed.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
