Removing Z oil filter is a PITA!!!
Old Oct 7, 2007 | 03:24 PM
Mazinger Z's Avatar
Mazinger Z
Default Removing Z oil filter is a PITA!!!
Everytime I change the oil, it is such a pain to take off the oil filter. I have my V1 lip bolted on to the bumper so I can't take off the under tray. Trying to unscrew the filter thru that little opening is almost impossible. I have the craftsman adjustable oil filter remover thing and it sucks *** big time. Any techniques you guys use to remove it? Please share.
Old Oct 7, 2007 | 03:44 PM
JonsilvZ's Avatar
JonsilvZ
You have to remove the rear part of the undercover. I put mine on ramps and it is a ***** to remove the filter.
Old Oct 7, 2007 | 03:45 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
i remove 3 or 4 bolts and bend down the undertray
never been a problem
Old Oct 7, 2007 | 03:47 PM
SuperBlack350z's Avatar
SuperBlack350z
it's so easy. what are you talking about? Get the K+N oil filters. They will benifet you. It has a socket screw at the bottom of the filter so you can just stick a socket and wrench in there from the bottom. Very easy. I usually just twist off with my hand though. It shouldn't be on there tight.
Old Oct 7, 2007 | 03:52 PM
Mazinger Z's Avatar
Mazinger Z
k&n ? hmmm never used one. I always use oem nissan long filters. Maybe I'll give that a shot.
Old Oct 7, 2007 | 04:37 PM
SuperBlack350z
the only downside is that it cost about 12-14 dollars per filter but aleast it's not a crappy brand. KN is very good with filtering. here is a generic pic.
Old Oct 7, 2007 | 04:46 PM
Jay'Z's Avatar
Jay'Z
I was going to recommend the K&N also........
Old Oct 7, 2007 | 09:57 PM
bluespecv03's Avatar
bluespecv03
I have an oil filter wrench that essentially works like pliers. It grips around the filter and when you squeeze it a bit hard, actually dents into the filter so it cant slip. Works perfectly and has made oil changes alot easier on many of my vehicles.
Old Oct 7, 2007 | 10:21 PM
hodahkwen's Avatar
hodahkwen
I do the same thing and it makes changing the filter very easy.
Old Oct 7, 2007 | 10:43 PM
Teufel's Avatar
Teufel
Im using a K&N, but after reading some posts, I wondering if it's really worth the extra expense over the Nissan OEM
Old Oct 7, 2007 | 10:46 PM
LaoSiFu's Avatar
LaoSiFu
K&N grip are awesome. Makes oil changing a lot easier.
~Robert
Old Oct 8, 2007 | 07:17 AM
INTIMAZY's Avatar
INTIMAZY
Thumbs up
+_1 on K&N
Even if it was NO better than stock, I would still get them just to ease installation.
http://www.amazon.com/K-N-HP-1008-Oi...1856217&sr=8-1
$9.49 plus potentially free shipping
Old Oct 8, 2007 | 09:21 AM
silverbullet_Z's Avatar
silverbullet_Z
i take out all 16 of them so i dont get any oil spills on it. Plus it also gives me a little more "ME" time away from the wife..
Old Oct 8, 2007 | 09:38 AM
Ztalker's Avatar
Ztalker
there is a thread on oil filters if you search for it....the best bang for the buck is Purolator.
Old Oct 8, 2007 | 09:45 AM
Mazinger Z's Avatar
Mazinger Z
Really? Or are you joking? Isn't Purolator an autozone or pep boys brand???
Old Oct 9, 2007 | 08:48 AM
FRLDYZPIMPN's Avatar
FRLDYZPIMPN
+1. I also use the filter pliers. It's almost effortless.
Old Oct 9, 2007 | 02:24 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
I just changed the oil on my Z this past weekend, and I don't know what you guys are talking about, but that was the easiest thing I've ever done in my life. All I did was put the Z on ramps...take off the under panel, use the oil filter key that I purchased at advanceautoparts for $3.00, and so on...took me about 45 minutes since that was the first time I did it myself & I had a bit of a problem getting the old copper crush washer off the drain plug. But I do realize you have your lip bolted onto the bumper so that might make it a bit tricky...good luck in the future : )
FYI: I got a damn good deal on the OEM oil filters through one of our sponsors..box of 20 filters and 20 crush washers!
Old Oct 9, 2007 | 02:47 PM
VO...'s Avatar
VO...
Administrator
I've got the same lip, but no bolts that interfere with the undertray.
Old Oct 9, 2007 | 02:49 PM
lbz's Avatar
lbz
+1 on the plier style oil filter tool. I took my undertray off, it's sitting on my balcony.
Old Oct 9, 2007 | 03:12 PM
Mazinger Z's Avatar
Mazinger Z
The lip covers the front bolts so u can't take it off. I just unbolt the back 4 and reach in that way. Do you take the whole thing off to do an oil change?
