Sputtering During Warm-up
Old Nov 11, 2010 | 09:38 AM
  #541
FastGreg's Avatar
FastGreg
Bad news from Nissan dealer, no update software available for our ECU....
And it seems that the Nissan dealers can't reinitialize the ECM with the Consult III, damned it !!!
Old Nov 11, 2010 | 02:12 PM
  #542
NyCSnEaK's Avatar
NyCSnEaK
Hey Greg,
Are the 07-08 G35 Sedans having similar issues?
Old Nov 11, 2010 | 09:24 PM
  #543
FastGreg's Avatar
FastGreg
Originally Posted by archangel72
^Thanks. I haven't posted on this thread yet, but have been having the same problem. It wasn't always like that I bought my 07 base used last September, and this strated happening maybe 6 months or so. Oddly enough, it rarely happens to me in the morning, it almost always does it when I leave work in the afternoon, when the car has been sitting in the sun all day. Once I start the car if I put it in gear and leave right away theres less of a chance of it sputtering. The lower the gear the more violent the sputter, but like you guys said, if i just let what ever gear i'm in wind-out it will go away
Same issue that us, we're a lot with the same problem, but anyone with a solution, Nissan included
I'm really don't know what Nissan waiting for to solve this huge issue!
I'm fed up with this story...
  #544
FastGreg's Avatar
FastGreg
Originally Posted by NyCSnEaK
Hey Greg,
It seems no... I also guess that 350Z Roadster / AT are not invovle with this issue, as different ECM too...
Old Nov 12, 2010 | 06:44 AM
  #545
FastGreg's Avatar
FastGreg
Originally Posted by 108NismoZ
UPDATE 1: sunday performed AAM HR Reflash and Dyno'd the vehicle. so far today during warm-up no sputter noted. i will be driving vehicle everyday to see if this fixed it.
108NismoZ, could you please confirm us that the AAM reflash definitively fix the issue ? Thanks a lot for the feedback, will bevery helpfull !
That it seems some "flash" don't solve the problem:
Originally Posted by srsairbags
was bored . . called up nissan consumer affairs . . . it seems the ECM is part of an emission control warranty and is covered till 4 years/80k miles whichever is earlier . . .
but im still curious . .as to why the techno-square re flash didn't fix this . . . even osiris for that matter
Unfortunatly, performance reflash ECU/ECM seems to be the only solution...
Old Nov 14, 2010 | 11:51 PM
  #546
FastGreg's Avatar
FastGreg
Can all the owners involve with this issue can take a picture and note the VIN number of their ECM/ECU ?
Then, we will able to make a list of all the ECU, and person, then to send it to Nissan...
http://www.alteredatmosphere.com/man..._ECU_Flash.pdf
Old Nov 15, 2010 | 06:30 AM
  #547
SQLSolarZ's Avatar
SQLSolarZ
I have older AAM reflash for HR and have sputtering. Did AAM redesign the flash update?
Old Nov 15, 2010 | 06:45 AM
  #548
FastGreg's Avatar
FastGreg
Thanks for the input SQLSolarZ.
Don't know if AAM design update reflash for HR
And why AAM reflash solve 108NismoZ's sputtering...
Anyway, I noted several common symptoms that maybe help:
- The P0300 Random misfire DTC code, may occur when you insist to rev the engine during sputtering around 2000 rpm,
- The high idle, around 900 rpm with a warm up engine (A/C off),
- Exhaust sound unusual,
- And of course the 1800 rpm sputtering... Lower gear, higher sputter... Lower speed, higher sputter.
-It also seems that 100 RON octane fuel solve the issue.
All that symptoms look like a lack of fuel, or too much air, then: lean condition... But too weak to throw a DTC !
Old Nov 15, 2010 | 06:50 AM
  #549
SQLSolarZ's Avatar
SQLSolarZ
Thanks FastGreg. I'll try to get it to throw a code and compare.
Old Nov 15, 2010 | 06:55 AM
  #550
MM'08_350Z's Avatar
I also went for a Re-tune in Austin TX. Because they had said they could help me with that sputtering problem, cuz they had also uptdated their software/program got home and turned it on the next morning and no luck. Sputtering is still their to this date.
Old Nov 15, 2010 | 07:14 AM
  #551
FastGreg's Avatar
FastGreg
Unfortunatly, it seems logical as ECU designers re-write the ECU map under the stock data... And don't start from scratch. They just adjust some parameters, for exemple UpRev:
Idle RPM
Speed Limiter Electronic
Throttle Control to achieve Wide Open Throttle at all speeds.
Rev Limiter
DTC disable
AFR Targets Fuel
Compensation Ignition Timing Advance Cam Phasing for equipped vehicles.
If our problem come from another parameter, no way...
Like this one for exemple (use translator): http://blogs.yahoo.co.jp/neko_technology/1843053.html
Old Nov 15, 2010 | 07:34 AM
  #552
FastGreg's Avatar
FastGreg
Maybe, it will be a good think to list all the owners (FastGreg, SRS Airbags, SQLSolarZ, MM'08_350Z, archangel72, Barbade, Stylett9, Diablo25mn...) who deal with this sputtering (you can easily confirm the symptom with the several videos), and mention all the specs of the car: year, model, AT/MT, VIN, mods, ect ?
List should appears in the first message of the 3 years old thread
As it seems we're a lot !!!!
Old Nov 15, 2010 | 07:53 AM
  #553
srsairbags's Avatar
srsairbags
mine is as follows
2007 model year (but manufactured in 2006 December), Enthusiast, MT, JN1BZ34DX7M502162
currently 36k miles (owned it since 30k - it was sputtering since the start)
have the following mods - ( ive checked and the sputter didnt change before /after mods)
1. BERk HFC
2. k&N Drop ins (helped reduce sputter a tiny bit)
3. COBB post MAF Hose
4. Grounding kit
also replaced battery with a brand new one
have now learned to live life with sputter
Old Nov 15, 2010 | 08:32 AM
  #554
bardabe's Avatar
bardabe
2007 Model, Manual Transmission Base Model. (Manufactured in 2006) Bought it at 30K now 61K
Mods are as follows
Nismo R-Tune Intakes + My Own Custom extensions
Bardabe Performance Test Pipes
Bardabe Performance X Pipe
Greddy Evo 2 Exhaust
Dyno Tuned by Seb @ Specialty Z.
Old Nov 15, 2010 | 09:29 AM
  #555
MM'08_350Z's Avatar
Mine is a 2008 350Z Base M/T JN1BZ34D28M705869
14100miles
MODS:
1. Stillen Headers
2. Berk HFCs
3. Stillen Y-pipe
4. Amuse mid pipe and axle back
5. Injen Dual Intakes
6. Osiris Reflash & dyno tune (twice)
Last edited by MM'08_350Z; Nov 15, 2010 at 11:30 AM. Reason: I forgot everyone was listing their modifications. :-(
Old Nov 15, 2010 | 09:47 AM
  #556
SQLSolarZ's Avatar
SQLSolarZ
2007 Enthusiast M/T (Mostly stock)
43,000 miles (started sputtering around 30k)
MODS:
1. AAM ECU Reflash
2. K&N Replacement Filters
3. AAM 3" Single Exhaust
Old Nov 15, 2010 | 11:13 AM
  #557
BlaQ350z's Avatar
BlaQ350z
2007 Touring M/T USDM
35,000 miles but started sputtering since around 15,000 miles
MODS:
Still stock but will be installing soon:
* Stillen Gen 3 CAI
* Stillen Headers
* Motordyne ART pipes
* Motordyne TDX V2 cat-back
Hopefully it will go away after i install and an UPREV tune (not too hopeful )
Old Nov 15, 2010 | 05:10 PM
  #558
archangel72's Avatar
archangel72
2007 Base m/t(don't know if they have a/t bases'), bought it with 26k miles now has 36k. I'll edit in the vin when I check later.
Bone stock.
Old Nov 15, 2010 | 11:20 PM
  #559
FastGreg's Avatar
FastGreg
If you're agree I will list all the persons and cars with this problem, the we will be able to send it to Nissan ?
It will be helpfull I think if you can note your ECU VIN also... Or check with Nissan Fast the ECU reference.
Old Nov 16, 2010 | 08:02 PM
  #560
bapestah's Avatar
bapestah
Hoooooooooly isht at all the new info since I last checked this thread. Well it's been another year since I posted my video/story and, like religious clockwork, my car is still sputtering on a daily basis.
Great info you guys have been getting during the past 6 months though. My details are as follows:
2007 Base M/T. Bought used with 11,000 miles.
Currently has 39900 Miles, Issue started around 15,000 miles.
Only engine mod:
Turbo XS catback
Had the issue checked by two dealers last year when I used to live in Miami, and went through a 2 month ordeal in which my car was at the dealer almost every weekend. After no one could find an answer Nissan brought in some Regional Tech Guru, and all he could say was "It's your engine oil." After about 10 oil changes, it's pretty clear my oil consumption is not the issue here.
I've been ignoring the problem for about a year now but reading the last 10 pages I hadn't caught up on got me all riled up again >____<
