Sputtering During Warm-up
Old Feb 4, 2011 | 10:12 AM
  #601
archangel72's Avatar
archangel72
I can't remember when the last time I posted on this thread was, but my Z has not sputtered for a long time. I haven't even thought about it. It might have stopped when I last changed my oil. I went with a sythetic blend from nissan. However, I will state that I used to wait until the engine was warmed up, and thats when it sputtered. I just put it in gear shortly after I start the engine and haven't had that problem...........yes, I'm confused too.
Old Feb 4, 2011 | 10:14 AM
  #602
bapestah's Avatar
bapestah
Originally Posted by srsairbags
when i bought my car 06/2010 . . it had 30k miles and was running a synthetic blend of Castrol . .sputter was mild . . . i did an oil change with Valvoline Synthetic . . sputter came out n was fully noticeable . . . ran 2 changes of mobil1 5w30 . . . sputter became slightly more imo . . ran GC 0w30 . . now the timing of sputter is much earlier after startup . . . im confused as hell . . . im getting the picture that oil is definitely related . . . i actually tryed to get Motul but couldnt find it anywhere . . . am thinking about the redline 5w30 (which is also ester based)
I bought Motul at a performance shop in Miami and it didn't last a week on my car -___- I originally thought oil HAD to influence the issue but it's been about 6 oil changes since it began occurring and i've yet to see a change no matter the difference in oil
Old Feb 7, 2011 | 12:25 PM
  #603
srsairbags's Avatar
srsairbags
at this point im soo desparate that ill try anything that i can to see if things change . . i can only assume that things will get better . . .cause my car sputters everyday without fail
Old Feb 10, 2011 | 08:56 AM
  #604
D'sNuts's Avatar
D'sNuts
My car was doing this so I reset the tps via manual instructions and it stopped
Old Feb 11, 2011 | 02:27 PM
  #605
bardabe's Avatar
bardabe
just get your car tunned, and have the Cam Phasing disabled until its at operating temp. it's not like you are going to drive your car hard when it's cold right? so power loss wont be aparent, no sputter problem solved. it's not hard guys.
Old Feb 18, 2011 | 11:15 AM
  #606
stylett9's Avatar
stylett9
ok . . im having a weird hunch that as the engines keep on sputtering (even for whatever little time) at every start up, engine components are gonna get messed up . . like the spark plugs etc may be getting fouled etc . . do you guys agree ? . . . point being . . down the road . . after a few years . .we will be needing an overhaul maybe much sooner than the guys who do not sputter . . or atleast spark plug replacement etc . . has anyone seen the spark plugs for their cars that sputter ? ?
Mine's been sputtering for over 3 years now. So far no noticeable signs of major damage.
Old Feb 20, 2011 | 06:56 PM
  #607
srsairbags's Avatar
srsairbags
have you looked at your spark plugs ? would sputtering foul plugs ?
Old Mar 2, 2011 | 09:24 AM
  #608
FastGreg's Avatar
FastGreg
Dear All,
Could you please have a look on the following web page with Google translator:
http://oppama-garage.jp/maintenance_..._20070408.html
http://translate.google.fr/translate..._20070408.html
So, what do you think about it ?
Old Mar 7, 2011 | 05:54 AM
  #609
srsairbags's Avatar
srsairbags
goodness . . awesome find fastgreg . . . i couldnt go through the whole page, but this is further proof that the VCT system is causing the sputter and the engine oil could be the culprit here . . but i couldnt make much out at the end . . is the article asking us to go thinner than 5w30 ? . . any suggestions ? ?
Old Mar 7, 2011 | 11:11 AM
  #610
FastGreg's Avatar
FastGreg
No, as I understand, 5W30 only, they do several test with 5w30 oils.
http://translate.google.com/translat..._20070912.html
And this is the oil recommended by Nissan for the VQ35HR:
oil_keep_200903.pdf
But... Nismo just issued an Ester oil made by Motul for the VQ35HR which is an 0w30 oil...
Nismo%20Competition%20Oil%202108E%200W30_GB[1].pdf
So...
Currently, I run with the Motul 300V 5w40, and with sputtering...
My ECU has been tuned, I changed my spark plugs last Sunday, cleaned the MAF, the throttlle bodies, and it is still sputtering !
Previously I changed the O2 sensors.
Still no DTC !
Next level: 5w30 300V oil...
Old Mar 7, 2011 | 04:26 PM
  #611
srsairbags's Avatar
srsairbags
Smile
Attachment 310198
Attachment 310199
So...
Still no DTC !
ok, feels good that we have pretty much nailed it down to oil . .and VCT of course
Im gonna try the redline 5w30 ester oil (i cant get Motul anywhere nearby) . . . although im pretty sure it will still sputter . . i wanna give it a shot . . do let us know what happens to your sputtering after Motul 300v
Old Mar 7, 2011 | 07:48 PM
  #612
FastGreg's Avatar
FastGreg
Don't forget to change your oil filter in the same time, as I understand the issue come form the viscosity of the oil at 80°C, which occur a wrong work of the solenoid (VTC) regarding the informations sent by the ECM, if not 5W30...
Old Mar 8, 2011 | 01:15 PM
  #613
srsairbags's Avatar
srsairbags
k&n wrench-off oil filter from now on . . last time i use Mobil1 oil filter and while taking it off , part of my hands skin came off ( in the inside of the nylon glove) . . . ridiculous
Old Mar 9, 2011 | 05:41 PM
  #614
Z+Lotus+Vette's Avatar
Z+Lotus+Vette
Default Just got this problem in my 2003 AT 70k miles
I can't believe this has not been settled in 31 pages and 4 years!
I plan to try the original suggestion of DryGas, since at my most recent fill-up the pump ran veerry slowly, indicative of the stations tank being very low. Probably got a bad tank of gas.
I had the bucking so bad that I could only creep around in "D"...any application of gas threatened stalling.
I did the "Microsoft", and shut off the car and turned back on. This allowed me to get out of the lot and start driving, but the problem recurred as a stutter at the first traffic light.
Additionally, it was cold and raining today, so I turned the key very quickly and immediately. After some questionable starts a month ago, I have been allowing the fuel pump to "prime/pressurize", by pausing in the "ON" position before going on to "START". This is the first time I have not followed this procedure since then.
(Lotus cars require such a pause, or they have a very rough and stumbly start.)
I almost drove it straight to Nissan, glad I checked here first.
"Can not duplicate" is the most common diagnosis I have ever gotten from mechanics. Diagnosis is a lost art.
Old Mar 10, 2011 | 06:50 PM
  #615
srsairbags's Avatar
srsairbags
i am afraid you are having an unrelated issue with similar symptoms . . . this issue is specific to 07-08 350zs (HRs)
Old Mar 20, 2011 | 04:07 AM
  #616
FastGreg's Avatar
FastGreg
So, today I swapped my oil with 300V 5W30, and guess what... STILL SPUTTERING, but less I feel...
Previously I runned with 300V 5W40.
I will keep posted after few more start !
Old Mar 25, 2011 | 05:02 PM
  #617
srsairbags's Avatar
srsairbags
i think it will gradually stop doing it
Old Mar 26, 2011 | 01:41 AM
  #618
FastGreg's Avatar
FastGreg
New cold start yesterday, no sputtering...
After several starts I will be able to provide you with a consistant feed-back.
I already order some Castrol Edge Sport 0W40 for a last oil trial !
But it seems that the issue really come from the motor oil...
Old Mar 26, 2011 | 02:25 AM
  #619
midz350's Avatar
midz350
It's not the oil guys.
Old Mar 27, 2011 | 08:50 PM
  #620
FastGreg's Avatar
FastGreg
What do you think about Midz ?
