Sputtering During Warm-up
Old Jul 13, 2008 | 04:50 PM
  #241
j.arnaldo's Avatar
j.arnaldo
Thumbs down
Somehow, I don't feel it has anything to do with the type of oil you're using.
Sounds more like an injector, bad gas (i.e. polluted with microscopic debris) or electrical problem. The stealership WILL charge you a lot for whatever
check-up they may make, unless you're under guaranty.
____________________________________________________________ _____
'O4 Touring Coupe/FLAWLESS AT!!!/13k!!!/$2O,5OO!!!/NO feathering!!!!!!!!!!!!!
Old Jul 14, 2008 | 05:31 AM
  #242
108NismoZ's Avatar
108NismoZ
UPDATE 1: sunday performed AAM HR Reflash and Dyno'd the vehicle. so far today during warm-up no sputter noted. i will be driving vehicle everyday to see if this fixed it.
Old Jul 14, 2008 | 08:25 AM
  #243
stylett9's Avatar
stylett9
could it be a tuning problem?! goodluck! I know Profink did the techno square reflash and it didn't fix anything but maybe you'll have better luck. Keep us posted.
Old Jul 15, 2008 | 07:50 AM
  #244
108NismoZ's Avatar
108NismoZ
update2: today no sputtering under warm up. my wife having the same exact vehicle however has stated she is still experiencing the sputtering during the warm-up even after the flash. i'm going to be testing tomorrow as well to see if the sputter occurs.
Old Jul 15, 2008 | 08:18 AM
  #245
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
108Nismo's wife here....
car still bucks like a freaking bronco at 2,300-2,600 rpm's during warm up.
Old Jul 15, 2008 | 11:51 AM
  #246
stylett9's Avatar
stylett9
your seems to buck at a different RPM range, but when you say buck, that really makes me feel it's the exact same problem.
to help cope with my bucking since i almost rear ended a car awhile back is to feather the clutch like your new to driving manuals. you know where you rev and accelerate with the clutch only half way out? this will obviously wear your clutch out pretty quick if you drive like this all the time, but i do it only when the "bucking" happens, and it helps make me not get so aggrivated.
Old Jul 16, 2008 | 06:06 AM
  #247
108NismoZ's Avatar
108NismoZ
Update 3: today during warm up in am nothing abnormal noted. did feel possibly at one point like it was going to act up but it didn't. so far so good. also the past 2 evenings leaving work have not felt anything during the warm up either.
Old Jul 16, 2008 | 07:38 AM
  #248
Tac-M's Avatar
Tac-M
it seems that driving hard right away, sometimes alleviates the problem.
but, taking it easy first few minutes makes it very noticeable.
so could it be a difference in the Exhaust Temp that messes with o2 sensors ???
Old Jul 17, 2008 | 03:28 PM
  #249
108NismoZ's Avatar
108NismoZ
Update: i haven't noticed anything to day as far as sputter, all weak under different times of day different scenerio's i've tried to make this thing sputter and i can't. so far so good. maybe it's a coincidence but since the reflash i've been running fine.
Old Jul 17, 2008 | 04:50 PM
  #250
Tac-M's Avatar
Tac-M
if that is so.... arg !!!!!
Old Jul 17, 2008 | 07:01 PM
  #251
Ataru074's Avatar
Ataru074
damn! looks like we'll have a good reason to reflash!
Old Jul 21, 2008 | 06:50 AM
  #252
108NismoZ's Avatar
108NismoZ
true
update: all last week no issue. no insane bucking or anything. hopefully i won't be wrong and it start up sometime later. but so far so good.
Old Jul 21, 2008 | 11:32 AM
  #253
stylett9's Avatar
stylett9
true
man....
definately keep us posted on pro-longed driving and if it ever comes back. If a reflash solved your issue, i wonder what is it about the tuning that is not right... and why it's not consistant with ALL z's.
Old Jul 21, 2008 | 11:37 AM
  #254
Ataru074's Avatar
Ataru074
Originally Posted by stylett9
man....
what I'd like to see... if he's going to do it once... is a dyno sheet with the A/F ratio. from really low rpms...
just to compare with what we have right now... the best could be also the timing map.. but ok.. enough.
I'm surprised that profink still has the problem with the technosquare reflash.. and he hasn't with the AAM (they should be the same... unless AAM has personal specs for that.)
Old Jul 21, 2008 | 02:49 PM
  #255
108NismoZ's Avatar
108NismoZ
don't have the before dyno sheets yet don't know why but here is after
Old Jul 21, 2008 | 04:43 PM
  #256
Sick Z's Avatar
Sick Z
I wanted to add that I also have this same issue, I just been dealing with it. Eventually Nissan will have to catch on to it, just like the slave cylinder recall. But it did start occuring around Decemberish.
Old Jul 25, 2008 | 08:17 AM
  #257
evil_tt's Avatar
evil_tt
18 days spudder free here!
Old Jul 25, 2008 | 08:20 AM
  #258
Sick Z's Avatar
Sick Z
What did you do? THe iso heat?
Old Jul 25, 2008 | 08:39 AM
  #259
evil_tt's Avatar
evil_tt
I changed my oil to sythetic Lucas w/ 1 quart of synthetic oil stablizer, ran around for about 6K (made the spuddering alittle worse) and recently changed back to synthetic castrol about 3 weeks ago and haven't had a spudder since. This was a daily issue but so far the engine note will change when its warming up and when it usually would start spuddering it just stops now.
Old Jul 27, 2008 | 06:30 AM
  #260
108NismoZ's Avatar
108NismoZ
so far so good for me since the flash. i'm hoping this isn't a weather related thing like when the temperatures start getting colder.. but i thought we already ruled that out so who knows.
