AC belt rips off again
Old Nov 23, 2007 | 06:03 PM
gabez33's Avatar
gabez33
thanks Eazzzzzy, I'll be getting this replaced 2morrow.
Old Nov 23, 2007 | 06:05 PM
SuperBlack350z's Avatar
SuperBlack350z
Hey Eazzzzy, wouldn't technically the car be a bit faster with no belt?
Old Nov 23, 2007 | 06:19 PM
Eazzy's Avatar
Eazzy
Are you kidding ??? If not... No not really, there is a relay that kicks out the compressor Clutch in WOT. Plus--the A/C needs to cycle to, 1) reduce humidity and 2) to keep the compressor seals lubed
Windows may Fog if the air is warm AND moist (an A/C is a dehumidifier)
Old Nov 23, 2007 | 06:28 PM
SuperBlack350z
lol, sorry if it's a stupid question. I just thought if there is nothing running the ac compressor, there would be less power being used up. Like some people who take out their whole AC system.
Old Nov 23, 2007 | 07:37 PM
gabez33's Avatar
gabez33
hey, so how long could I drive without the belt? Is it gonna damage anything? Its cold here and I turned on my heater/ac and it seemed to work and blow fine...sorry if my ? seem a little ignorant but am a complete noob in this department...thanks
Old Nov 23, 2007 | 07:40 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Originally Posted by sean1967
A deep groove pully would help if you find the belts aren't loose, but make sure you don't have another mount bolt loose somewhere....if you do you will just start breaking things if you put a deep groove pully on.
A deep groove pulley is for v-belts, the z takes a serpentine.
Old Nov 23, 2007 | 07:52 PM
Eazzy's Avatar
Eazzy
Super .....not stupid. The A/C removal is for a weight savings---Though what amount I dont consider worth much. If the clutch is not engaged, then there is no power drain to speak of
And Gabe ---as I said --Even with the heater on the A/C will cycle so as to dehumidify the air mainly for your defroster. You can run with out the belt for as long as you want, but in time ur compressor seals will dry and leak
Old Nov 23, 2007 | 07:56 PM
SuperBlack350z
Good info. I haven't even drove my car for over two months now so i will definitely put one on when i get back.
Old Nov 23, 2007 | 08:03 PM
gabez33's Avatar
gabez33
Thanks eazzzzy! I appreciate the reply... you da man!
Old Nov 23, 2007 | 08:16 PM
Eazzy's Avatar
Eazzy
I was rushed earlier----The pulley on the compressor just free wheels untill the cluch on it is engaged electromagnetically. It then will cycle on and off dependent on need and internal Pressures. There is a circuit that deactvates the clutch on WOT so you dont throw a belt AND so you get full engine power output (No Drag)
The spinning shaft in the compressor keeps the seal lubed. If you leave it sitting to long --The seal will get a flat spot that is a potential for a leak ---Its not sensible to replace the seal ---you really need then to replace the compressor
Old Dec 28, 2007 | 02:03 PM
SuperBlack350z
Ok so my new Nissan belt ripped off again. It's pissing me off. Nissan is telling me that i'm hitting past redline? I did accidently hit my rev limiter last night while driving aggressively. I just got the car back from some other things installed on my car. can this be right? Maybe Eazzzzzzy has an explanation for this. All i know is belts are getting expensive.
Old Dec 28, 2007 | 03:35 PM
Corradoslc7's Avatar
Corradoslc7
The belt shouldn't tear off because you hit the rev limiter. There is something else your missing, I would check the entire belt area for signs of rubbing.
Old Dec 28, 2007 | 03:36 PM
JonsilvZ's Avatar
JonsilvZ
Reving high in my 03 Z with 36k+miles belts are fine.
Old Dec 28, 2007 | 03:52 PM
SuperBlack350z
there is no play in any tensioner or pulley itself. They all rotate freely(not too fast but not too slow). Nissan thought my pulley was seized but that wasn't the case.
Old Dec 28, 2007 | 04:13 PM
HondaKiller's Avatar
HondaKiller
I've never had them rip off but the last time i changed them they were pretty well ate up. I suppose if they went any longer they could have snapped. Easy swap though, takes about 30mins.
Old Dec 28, 2007 | 04:15 PM
SuperBlack350z
Yeah, my problem is they get eaten up then start shreading. Takes about 10minutes, i just spend 100 bucks on belts so far though. This would be my 5th belt. It's actually really getting on my nerves and all Nissan said was to stop over revving.
Old Jan 2, 2008 | 03:36 PM
fklentz's Avatar
fklentz
When did this start happening? Did you install something or have something done before the belts started shreding, I'd think that there's an alignment problem with the pulleys. Try this, pull the fuse or relay for the A/C compressor and drive as you normally do, if the belt starts to shred then that could rule out the compressor itself and look at an alignment issue.
Old Jan 2, 2008 | 04:03 PM
  #38
SuperBlack350z
Nope, haven't installed anything engine related.
Do you mean pull out the fuse and leave it out?
I just put on a gatorback belt two days ago. Seems ok so far but i haven't really driven it much.
Old Jan 3, 2008 | 03:51 AM
  #39
fklentz's Avatar
fklentz
Here's the deal, did this just start happening OR has it been happening ever since you bought the car. If it just started to happen then try to rule out causes, if you pull the fuse or relay so that the A/C compressor cannot engage and then the problem goes away then you can be certain that it's related to the compressor, if the problem is still there then it's an alignment issue of the pulleys. It is possible the A/C compressor is putting excessive belt drag due to something failing in it.
Did you install aftermarkt equipment, are the pulleys factory or did the previous owner install aftermarket under drive pulleys.
3vilbunny
Jul 18, 2017 05:10 PM
Juztin
Nov 22, 2015 07:03 AM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
