Tighten my drive belt too much =(
Old Nov 14, 2007 | 06:04 PM
doreamon50's Avatar
doreamon50
Default Tighten my drive belt too much =(
How you all doing, I replaced my drive belt about a month ago, but everytime during the morning when I start my car cold, the engine will make a really loud squeeking sound, so I decided to tighten my drive belt more tighter on monday, and after I put about 200 miles on the car this past couple days, I start hearing a whinning sound when the engine rev above 2000 rpm. I think I tighten the belt alittle too much, so I loosen the belt abit, but it's still making the whinning sound now. Did I break anything, is my engine alright??
Old Nov 14, 2007 | 06:08 PM
SuperBlack350z's Avatar
SuperBlack350z
How many miles have you put on the belt? You are suppose to torque the tensioner bolts to nissan's recommended spec. It will have a whiney sound until the belt has time to stretch a bit and it will be normal again after about 150 miles.
Old Nov 14, 2007 | 06:40 PM
doreamon50's Avatar
doreamon50
I already put about 8-9k miles on the belt, but I retighten the belt on monday and drove it for 200miles, but the whinning sound is getting louder, and I'm afraid I'll break something, so I loosen the belt just about an hour ago, and I put about 20 miles
Old Nov 14, 2007 | 06:41 PM
doreamon50's Avatar
doreamon50
do you know what the torque spec for the tension bolt?
Old Nov 15, 2007 | 08:05 AM
Ztalker's Avatar
Ztalker
that whining sound might be coming from the power steering pump. Did you replace the belts yourself?
Old Nov 15, 2007 | 08:26 AM
HondaKiller's Avatar
HondaKiller
I had a similar problem awhile back. First when i changed my drive belts i changed them with aftermarket knock-offs. I could not get rid of the whine and initial start up squeal. After switching back over to the Nissan OEM set up, everything was good to go. Did you replace your belts with generics or OEM?
Old Nov 15, 2007 | 08:28 AM
SuperBlack350z
I have my guide at home..i'm on vacation at the moment so i can't get it right away. I'm sure someone else knows though.
Old Nov 15, 2007 | 08:29 AM
SuperBlack350z
I hope he has the OEM nissan. They are cheap.
Old Nov 15, 2007 | 11:37 AM
doreamon50's Avatar
doreamon50
I got the Goodyear drive belt, so I should switch back to OEM then
Old Nov 15, 2007 | 11:44 AM
HondaKiller
absolutley. If you switch back to the OEM nissan issued belts i am confident your problem will go away.
Old Nov 15, 2007 | 11:52 AM
VO...'s Avatar
VO...
Administrator
replace the belt. End of story...
Old Nov 15, 2007 | 11:54 AM
VO...'s Avatar
VO...
Administrator
There are no torque specs on a belt tension bolt. Tighten it to where there is no play in the belt when you tug on it with one finger. Like others have said, replace it with the OEM belt. After you install it and it has no play, drive it a couple more days, then re-tighten it again until it has no play...
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
