NEW window problem
Old Apr 7, 2008 | 06:57 PM
  #41
badboyz's Avatar
badboyz
mine also does this but its mostly the driver side window that goes down. I can kill the car and pull the key out of the ignition and the windows still operate up and down when it is screwing up. When they work right the windows do not allow me to go up or down after the key is out of the ignition. Im guessing my problem isnt the key fob...
Old Apr 8, 2008 | 08:03 AM
  #42
SteveZ's Avatar
SteveZ
No, from everything I've been able to figure out that points to the BCM. There are 2 different issues in this thread, one the key fob causing issues, the other seems to be the ignition switch role in the BCM unit.
I haven't had a repeat since I pulled the battery out of one of my 2 key fobs, the one with corrosion. Hoping that's the issue.
Old Apr 8, 2008 | 08:04 AM
  #43
SteveZ's Avatar
SteveZ
Originally Posted by Tim@Performance
Like I stated above...you have a remote problem. Even if no one is there to touch them, if there is a short inside one of the remotes it can trigger one of the buttons (unlock button) and cause the windows to go down. Remove the batteries and I guarantee it will fix it.
So far so good, thanks again for that tip.
Old Apr 9, 2008 | 08:50 PM
  #44
unknownuser's Avatar
unknownuser
Originally Posted by JonsilvZ
We could understand that because its a Dodge.
Jeep Liberty's aren't Dodge they are a division of Chrysler.
Dodge is also a division of Chrysler.
But Jeep and Dodge aren't the same.
nevertheless they all suck.
Old Apr 10, 2008 | 06:08 AM
  #45
SteveZ's Avatar
SteveZ
I see you're new to this forum, please try to stay on topic.
If you have info to contribute relevant to the thread, please post, otherwise don't.
Thanks
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
