Passenger Seat Won't Slide
Old Dec 11, 2007 | 05:43 PM
CarlosZ's Avatar
CarlosZ
Default Passenger Seat Won't Slide
I did a search with no luck. I got in the car one day, the passednge seat was on the most rear position of the rail and won't move. It's as if the motor is disconnected. I looked for a fuse checked (I couldn't find any for the power seats), checked wires (nothing noted), and tried the button of course no luck. Anyone know of anything to repair the seat so it slides back and forth? Thank you.
Old Dec 11, 2007 | 05:56 PM
djclongisland's Avatar
djclongisland
try holding it for 60 seconds
Old Dec 13, 2007 | 09:53 PM
CarlosZ's Avatar
CarlosZ
This site sucks, no one knows ****!
Old Dec 14, 2007 | 06:08 AM
Eazzy's Avatar
Eazzy
Everything has an order. First question....is it a Mechanical or Electrical problem? Either way, the seat will have to come out. Activate the motor from a source direct. Does it sound like it is trying ? If so, disconnect the actuation arm and do it again. Does it cycle ? If so, you have a Mechanical Problem. Simple.......Find it. Is it a piece of garbage in the track ? Do what has to be done to free up the slide assy and lube with white grease and what ever it is, see to it that it doesnt happen again
Back to square one...If the motor doesnt run from an outside source, then its bad. If it does and the sliders work, test the input line for pwer when activated. Is there a fuse? I dont know. Nissan is poor as far as identifying locations even in their Factory Books which I have. I may try to find it later
Old Dec 14, 2007 | 06:16 AM
Eazzy's Avatar
Eazzy
And this site doesnt suck if you get a little more involved with it ----A little over 2 posts a month over 3 yrs isnt too involved. I have a few more than that, and I get ignored, I dont lose sleep over it
Old Dec 14, 2007 | 09:05 AM
CarlosZ's Avatar
CarlosZ
When I push the button, nothing happens. As if the motor is either dead or is getting no power. I've looked at the fuse box under the hood and the one by the drivers left leg with no luck. I haven't been able to find any fuses related to the seat other than a heater fuse anywhere. I hardly use the button but I'll check the wires again. Thank you.
Old Dec 14, 2007 | 10:01 AM
Eazzy's Avatar
Eazzy
There is also a Fuse Block located BEHIND the Battery on the fire wall
Old Dec 24, 2007 | 07:55 PM
toy4two's Avatar
toy4two
my passenger seat will go forward but not back ? I'll have to pull it out and see whats up.
Old Feb 25, 2008 | 08:24 AM
CarlosZ's Avatar
CarlosZ
No luck still. I looked by the battery and saw a fuse box but no seat fuse. Anyone out there know of a fuse anywhere in the car that may be related to the seat motor? Is there an additional fuse box besides the one by the drivers feet and the one next to the battery? Other than these two, I have had no luck at all.
Old Aug 16, 2008 | 07:22 AM
CarlosZ's Avatar
CarlosZ
I've searched and checked all three fuse boxes, nothing. Does anyone know of a specific fuse for the power seats? I hardly use the seat controls and I have checked all the wires, rail, switch is clean etc. Anyone????
Old Aug 16, 2008 | 11:26 AM
j.arnaldo's Avatar
j.arnaldo
Thumbs down
Auto electrical shop time, CarlitoZ!---NEVER the stealership, though!!! Good luck!
(BTW, I'm impressed with your savvy, Eazzy! Your analysis was very thorough, dude! He's gonna have to take it to the auto electrical technician,
though).
Old Aug 16, 2008 | 11:44 AM
350 Rookie's Avatar
350 Rookie
take it to a pro, and get it done. problem solved
Old Jan 3, 2009 | 03:18 PM
Silver350zed's Avatar
Silver350zed
i know this is an old dead thread... the seat switches are bad switches and poorly designed. My seat is stuck in the rear most position and I cannot reach the pedals. Anyone know where to purchase new seat switches? The switches I have I attempted to rebuild but the problem is they're worn down so much in one direction that it doesn't work but works the opposite direction.
Rev_Night
Nov 7, 2020 06:00 PM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
