road noise? fix?
Old Jun 9, 2003 | 01:41 PM
nmilsaps's Avatar
nmilsaps
Default road noise? fix?
When I go over gravel or any kind of loose material, it sounds like a machine gun is going off. I'm sure it's loud in everyones car, have any owner's installed any type of insulation? in my opinion it seems to come from the wheel wells.
Old Jun 9, 2003 | 10:50 PM
kbiz's Avatar
kbiz
I've installed vb2 sound deadener to much of the car. Way Way quieter, but rocks kicking up are coming from the back wheel wells because there isn't the normal sub fender like the front. This is common on sports cars, but it would be nice if someone would make a sub fender for the back too. I would be interested in that. When it's wet out and my car has set, getting bits collecting around my back wheels, it kicks up a bunch until the Z kicks them all off. Normal but lame...
Old Jun 12, 2003 | 09:11 AM
Trackbite's Avatar
Trackbite
My road noise led to Nissan buying me to new front tires and realigning the front end. All done under the TSB identified on their Website.
Old Jun 12, 2003 | 12:48 PM
Trackbite's Avatar
Trackbite
Here are the details:
NTB03006
IF YOU CONFIRM: An applied vehicle shows the following symptoms when braking moderately: · excessive tire "roar" or "growl" noise, · mostly when braking at speeds below 30 mph. ACTIONS: · Verify the incident noise as described above. · Check Alignment. Adjust (if needed). · Rotate Front Tires from Side to Side - Dismounting Tires from Wheels. See this bulletin for detail.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
