The Z is Dead...Warranty Question
Old Jan 19, 2008 | 08:31 PM
JMS0825's Avatar
JMS0825
Default The Z is Dead...Warranty Question
So I turned on my car today drove it down the street...Check Engine light came on and the car seemed to be misfiring...I was driving it back to the drive way and Pop...Engines finished...The car completely shut down...Should this be covered uner my warrenty?
BTW I have an 03 Touring completely stock...
Old Jan 19, 2008 | 08:32 PM
Delako's Avatar
Delako
What year..how many miles..etc etc
ahhh...03..prolly out of warranty then
Old Jan 19, 2008 | 08:39 PM
I don't know the source of the problem.
I don't know if the car is under warranty.
Old Jan 19, 2008 | 08:55 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Mayb not brother...
Old Jan 19, 2008 | 10:18 PM
Zmazing03's Avatar
Zmazing03
'03?
Not unless you bought an extended warranty. Otherwise in January '06 its out of warrant, assuming it wasn't before that due to miles.
I have an '03 Z, under warranty until 92,000.
Old Jan 19, 2008 | 10:21 PM
blasian's Avatar
blasian
How do you know the engine is dead?
Old Jan 19, 2008 | 10:59 PM
terrasmak's Avatar
5 year 60k powertrain warrenty , you may be good as long as your not over the milage and when your car was brought into service.
Old Jan 20, 2008 | 12:03 AM
JMS0825's Avatar
JMS0825
Yeah I bought the extra warranty...The car has 50K on the dot...I thought maybe there was something wrong with the 03 engine like there is with the tranny...I know the engine is screwed because it wont rev past 2K RPMS if I push the throttle more than lightly and it will stall if I rev it with a heavy throtle...Could a new set of plugs be the cause of this...?
Old Jan 20, 2008 | 03:37 AM
JETPILOT's Avatar
JETPILOT
Your engine is fine... your ecu is in safe mode for some reason.
The dealer will hook up the Consult and pull the codes.
JET
Old Jan 20, 2008 | 06:22 AM
JMS0825's Avatar
JMS0825
Thanks a lot jet...
Old Jan 21, 2008 | 06:49 AM
DraGonAlchemist's Avatar
DraGonAlchemist
did you restart the car? it probably idled to low if it' s misfiring and shut off. . .or the car shut down so it doesn't do damage to the engine. .but start the car and see if it's misfiring. .how many miles do you have?
Old Jan 22, 2008 | 08:53 PM
derekinthez's Avatar
derekinthez
Who knows, pull out your warranty and read it. Then, take your car to the dealer.
Old Jan 23, 2008 | 05:38 AM
HondaKiller's Avatar
HondaKiller
if you don't see smoke and oil pressure, temperatures are stable then your engine is fine. Sounds like some sort of air leak to me. Pull your air filter out, check tubing for blockage. Then remove negative battery terminal, pump brake, reconnect terminal and your ECU is reset. I had a cheapo Autozone air filter for a hold me over in which the universal boot ripped off the filter and up the intake tube. Through my car into limp mode which is similar to what you are describing. Wont go over 2500 RPMs misfires like a ***** and dies everytime you push in the clutch.
Or did you get it to the dealer arleady?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
