noise in steering column when truning wheel
Old Jan 21, 2008 | 07:56 AM
kobalt's Avatar
kobalt
Default noise in steering column when truning wheel
I have an annoying plasticky rubbing noise when turning the steering wheel past a certain spot and its really annoying. I'm sure it's coming from inside the steering column but did not notice any apparent rubbing between the wheel and the column. Before I tear into the column to find the culprit did anyone had this happen and diagnosed / fixed the problem?
Old Jan 21, 2008 | 10:19 AM
Forever Z's Avatar
Forever Z
I have the same problem. I havn't lookind into it but I'm pretty sure it's coming the rubber that surrounds th shaft were it goes through the fire wall.
Old Jan 21, 2008 | 11:19 AM
kobalt's Avatar
kobalt
Mine sounds like its right in the steering wheel area...
Old Jan 21, 2008 | 11:29 AM
350ZTheStandard's Avatar
350ZTheStandard
What size are your front tires, have you lowered your Z car?? Because the wheel liner up front is made of plastic, are you getting the hint here???
Old Jan 21, 2008 | 12:45 PM
kobalt's Avatar
kobalt
The sound is coming from right behind the turn signal stack area. It happens while driving or stationary, car on or off. Something has to be rubbing in that area.
Old Jan 21, 2008 | 04:18 PM
seZy350's Avatar
seZy350
i use to have this problem only in the early mornings. it was weird. then all of a sudden it never happened again..
Old Mar 4, 2008 | 10:51 AM
chriskd's Avatar
chriskd
Anyone ever figure this one out? I'm hearing this on mine, too.
Old Mar 4, 2008 | 11:54 AM
Motormouth's Avatar
Motormouth
you should never trun your wheel, that's your problem right there.
Old May 7, 2008 | 01:14 PM
koolzero's Avatar
koolzero
I have something very similar to what you're describing. However in my case it sounds to me like the sound i'm hearing is coming more from the front suspension area. It seems to be more noticeable when turning the wheel while going down an incline.
I do have 19" rims and the car is lowered but I don't think it's rubbing.
If anyone found a fix to this noise I'm very interested to hear what it is.
Old May 7, 2008 | 01:38 PM
nyguy4u's Avatar
nyguy4u
I have the same problem. Weird thing is though, it only happens the first 2 or 3 times I turn the wheel when I first get in the car in the morning. Weird.
Old May 7, 2008 | 01:59 PM
jdavis169's Avatar
jdavis169
Mine does this only when I take a right and it's cold out.
Old May 7, 2008 | 06:14 PM
HondaKiller's Avatar
HondaKiller
Most likely just cold fluid and a noisey rack a pinion. Harmless untill your power steering starts dropping out randomly. I wouldn't worry about it unless it is inusence.
Old May 8, 2008 | 08:00 AM
j.arnaldo's Avatar
j.arnaldo
Possible lubrication of the steering "column" (i.e. the structure that goes down
below, into the fire wall). If not, rubber bearings may be cracked/smashed.
IF NOT, see your nearest mechanic--NEVER the stealership! Good luck, bro'.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
