sigh.
Old Feb 8, 2008 | 05:12 PM
ke0ki2k's Avatar
ke0ki2k
Default sigh.
can someone link me up to a DIY thread on how to change final drive/rear end oil? searched and I cant come up with one. I feel dumb.
Old Feb 8, 2008 | 05:47 PM
Eazzy's Avatar
Eazzy
There is a plug on the bottom for drain and one farther up for fill. Drain it, replace the plug. Remove fill plug, fill it until it runs out the fill plug hole. Replace plug. Drive Vehicle.
Dont feel Dumb.
Old Feb 8, 2008 | 07:02 PM
ke0ki2k's Avatar
ke0ki2k
yeah nvm guys lol, read up on a thread on 350zwiki. do I need a pump to fill the oil in? is it that big of a pain to just pour it in?
Old Feb 8, 2008 | 07:09 PM
Eazzy's Avatar
Eazzy
Its always tough with Trans and Diffs------I used to cut off the top of the bottle then slip some fuel line over it, insert it, and squeeze hell out off the bottle, then refill the same bottle and repeat.
Since then I got a deal that looks like a qrease gun but is like a big syringe, that pulls the fluid up then dispenses when I push the handle in
Old Feb 8, 2008 | 10:07 PM
350ZTheStandard's Avatar
350ZTheStandard
Use Royal Purple also, you should replace the washer on the drain plug when changing out the fluid in the pumpkin. I got a washer for my tranny and the rear end at the dealer today $4.35 each. Yea stealership!!!!
Old Feb 9, 2008 | 06:47 AM
HondaKiller's Avatar
HondaKiller
you can rent the pump at autozone or pep boys. It's not much and will help dramatically when refilling.
Old Feb 12, 2008 | 01:13 PM
VO...'s Avatar
VO...
Administrator
* sigh
Old Feb 12, 2008 | 01:22 PM
Eazzy's Avatar
Eazzy
OPs post #1 *sigh* tugged at my inner compassionate feelings towards his turmoil and pain. But since he hasnt responded with with an expected success story, those feelings have once again turned to Ice.
*sigh*
Old Feb 19, 2008 | 06:15 AM
Musto's Avatar
Musto
im just wondering, im a new z owner and just saw this thread, is this something that should be done at each oil change? and also if i take it to get the oil changed, is this something everyone would know to change?
Old Feb 19, 2008 | 11:50 AM
My350P's Avatar
My350P
Probably the same one you read, but:
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/131098-changing-the-differential-transmission-oil.html
Yes, you will need a "vacuum gun" or whatever, but you can find them at any car parts place really cheap. Makes it a million times easier.
@Musto: You should change the oil, oil filter and copper crush washer on the drain plug at the same time. Any lube place should theoretically do this.
Old Feb 21, 2008 | 11:18 PM
Musto's Avatar
Musto
how often do you change the transmission fluid?
kch44
Oct 5, 2016 07:25 AM
Rev_Night
Oct 22, 2015 12:11 PM
