driver side map light out
Old Feb 16, 2008 | 08:58 PM
TJ350Z's Avatar
TJ350Z
Exclamation driver side map light out
Hey guys Im kinda in a stump as to whats wrong here. my driver side map light is out. i swapped the bulb and the bulb is fine (when moved to the passenger side). i checked the fuse in the footwell (10a) and its not blown (otherwise the passenger map light wont work). i already disconnected the battery and still nothing.
is there another way to check this? anyone run into a similar problem? i was in the process of swapping out the bulb. after i seated the new bulb (PIAA), it didnt fire.
help
Old Feb 22, 2008 | 04:39 PM
Jimmyg41's Avatar
Jimmyg41
What you can also do is disconnect your battery for a few minutes then reconnect it. It resets the ECU. I had the same problem with both map lights out and the lights over the vanity mirror. Replaced the bulbs and nothing happened. Did the batter thing and sure enough it worked.
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
