help! water in headlight housing
Old Feb 28, 2008 | 12:45 PM
tiger333's Avatar
tiger333
Default help! water in headlight housing
how do you get water out of the headlight housing??? theres like moisture build up on the inside of my buddy's car. any one know how to get this out?
Old Feb 28, 2008 | 01:21 PM
Frank@MtroNiss's Avatar
Frank@MtroNiss
Default Moisture
most of the time it goes away be just leaving the highbeam on for a while
Old Feb 28, 2008 | 04:30 PM
reppintha510's Avatar
reppintha510
at the dealership we use a heat gun to evaporate the water, or you could use the high beam. but if in was mine i would get the water out then pull the headlight out and reseal the housing
Old Feb 28, 2008 | 07:54 PM
tiger333's Avatar
tiger333
thanx guys
Old Feb 28, 2008 | 07:56 PM
SuperBlack350z's Avatar
SuperBlack350z
if you stick a hair blow dryer in after you take a bulb out,it will dry it. The only thing is if the water is on the inside housing, the water will leave a hazy look because of the water being dirty.
Old Feb 29, 2008 | 09:08 AM
tiger333's Avatar
tiger333
thanx
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
