Auto Tranny question
Old Mar 19, 2008 | 08:12 PM
dimsum826's Avatar
dimsum826
Question Auto Tranny question
Got myself a 04.5 Daytona blue 350z Roadster. 30k miles on it. Wanting to change auto tranny fluid. Does anyone know how many qt of Matic J ATF its needs after old auto tranny fluid is drained? Thank you.
Old Mar 19, 2008 | 10:25 PM
Vader007's Avatar
Vader007
If your getting a flush (which is recommended) then you will need 12 quarts,
if your gonna just drop the pan and fill you shoud only need about 6.
Old Mar 19, 2008 | 10:27 PM
SuperBlack350z's Avatar
SuperBlack350z
yes, but i don't think you can do a full flush without a machine.
Old Mar 20, 2008 | 04:33 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Just had mine done. The details are or should be in the back of your owners manual. You also require the washer too, best to get that from Nissan (cheap as chips for the washer, it was less than NZ$3, so less US$). And yes you do need a machine to do the flush. It makes a huge difference.
Old Mar 20, 2008 | 08:04 PM
dimsum826's Avatar
dimsum826
Thank you very much all for all your advices and help. I guess i will take it back to the dealer so they can do the flush for me. BTW, does wheel alignment mean alot? my steering wheel is alittle off. When i drive on the level and straight surface, it somewhat steers itself to the right. Sorry for all the trouble. Thanx again.
Old Mar 21, 2008 | 03:34 AM
ZTUPID's Avatar
ZTUPID
It only matters if you enjoy having tread on your tires. Just get an allignment and call it a day. It's cheaper than buying tires. Good luck.
Old Mar 21, 2008 | 07:38 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Oh by the way, it's just under 20 litres (not sure what that is in imperial) required. When I priced the fluids up at the dealer with a trade discount, it was still NZ$95 per 5 litres, x 4 = eek. But DON'T scrimp or you'll end up with problems.
BTW, does wheel alignment mean alot? My steering wheel is a little off. When I drive on the level and straight surface, it somewhat steers itself to the right. Sorry for all the trouble. Thanx again.
Go get it sorted. Beside anything will make it easier to handle and drive, and you won't wreck your tyres, ultimately will save you a lot of $$$$.
Old Mar 23, 2008 | 07:25 PM
03aeroZ's Avatar
03aeroZ
isn't the rec time to change the AT fluid like 100k?
Old Mar 23, 2008 | 07:32 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
This is one of the things I say you should take it to the dealership and have done. The fluid is $10-$12 a quart, you'll need about 9. See what they want for a flush. If it's not that much more than you buying that much fluid let them do it.
Old Mar 23, 2008 | 07:37 PM
03aeroZ's Avatar
03aeroZ
anyone have the rec change mileage?
Old Mar 23, 2008 | 08:31 PM
Teufel's Avatar
Teufel
I believe it's 30K miles. I just had mine Tranny flushed @ 31K as part of recommended maint.
Old Mar 24, 2008 | 07:24 PM
dimsum826's Avatar
dimsum826
Great. Now i have decided, i should take it back to get it flushed. Since a bottle is $10, and getting it flushed is not that far apart in pricing from a Nissan Dealer. keep it nice and clean, at least from my end and for the auto tranny sack. Thank you all for all the great help.
Old Mar 24, 2008 | 07:30 PM
dimsum826's Avatar
dimsum826
Bronzee, You are right. I am going to get it sorted out at the dealer when i get my tranny flushed. kindof tired of driving with my wheel not aligned. thanx alot for ur reply.
Old Mar 25, 2008 | 06:11 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Bronzee, You are right. I am going to get it sorted out at the dealer when i get my tranny flushed. kind of tired of driving with my wheel not aligned. thanx alot for ur reply.
You're welcome. Let us know how you get on. You should see a big improvement in the way it shifts once done. Much smoother.
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
