Where is tensioner to replace belts
Old Mar 23, 2008 | 12:34 PM
WheelieMonster's Avatar
WheelieMonster
Default Where is tensioner to replace belts
I am tryin to replace the cerpitine belt on my 2003 350z and need a lil help to where the tensioner screws are to losen the belts?..in the process now so please help...thanks
Old Mar 23, 2008 | 01:01 PM
mysmokenz's Avatar
mysmokenz
the tensioner has a nut that in the center of the pulley loosen that nut then below the tensioner there will be a long bolt that holds the tensioner and is bolted to the motor as you turn the long bolt it will move the tensioner and make the belt loose or tight! make sure to tighten the nut in the center of the pulley when your done!
Old Mar 23, 2008 | 01:45 PM
terrasmak's Avatar
Both of them are accessed from the bottom.
Old Mar 23, 2008 | 04:19 PM
Spork's Avatar
Spork
The others have covered where the tensioners are.
I had to point out the horrific spelling error.
Old Mar 23, 2008 | 04:41 PM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/333152-diy-replacing-your-belts-very-easy.html
lapham3
Oct 7, 2022 03:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
