Window motor question
I have read the posts on window motors, but cant find the answer to this.
Me window motor went bad again on my 2004. I have a lifetime warranty through Autozone, however this is the 3rd replacement in 4 months.... do the newer cars have the same tendency to have window motors go bad, and if not, will the window motors from newer vehicles work in the older ones. Or of another place to get it that might be a better product. Autozone's supplier is out right now... 3 weeks wait time... they will give me a full refund on mine to go buy it someplace else.... by the way, I can replace the window motor from start to finish in 20 minutes...
Autozone is usually a decent supplier for there products,,sounds like you may just be having some bad luck,,,double check the regulator next time you have it apart,make sure that the wheel that carries the cable is straight or it may cause some drag causing your premature wear.
Originally Posted by 03aeroZ
how much is that autozone one? i need to fix mine, and i might just replace it instead of cleaning it.
