Part numbers for OEM Brembo seal kit
Old Mar 31, 2008 | 02:29 PM
turbotoy's Avatar
turbotoy
Default Part numbers for OEM Brembo seal kit
41120-12U25 is the part number for the front seal kit list for $29.68
44120-12U25 is the part number for the rear seal kit list for $57.46
These are complete! Includes seals, dust boots, and bleed screw rubber. One kit for the front calipers one kit for the rear calipers!
Old Mar 8, 2010 | 10:42 AM
SA Z-boi's Avatar
SA Z-boi
might need theses
Old Mar 8, 2010 | 01:31 PM
DavesZ#3's Avatar
DavesZ#3
You realize this is a two year old, nonsensical post, right?
Old Mar 8, 2010 | 02:46 PM
turbotoy's Avatar
turbotoy
I take offense to that
I thought is was good info!!! I waited two years for someone to reply.
nonsensical: I had to look it up
Old Mar 8, 2010 | 05:11 PM
DavesZ#3's Avatar
DavesZ#3
It looked like you were answering a question, but unfortunately your was the first post so to me, it didn't make much sense to have an answer when there was no question.
BTW - it's great info. I'll probably need it this summer cause I figure my Brembos are about due for a rebuild.
Old Mar 8, 2010 | 05:52 PM
turbotoy's Avatar
turbotoy
Some other info: there is an o-ring between the calipers that I haven't sourced so be careful if you take the two halves apart. Those don't come in the kits. I just reused mine but someone that really puts the heat to them may need to replace. The torque spec is 90ft/lbs for the caliper halves.
Just giving you a hard time
StateNuke08
Oct 31, 2015 05:01 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
